NCPA API Method of Data Collection
meganwilliford
For remote windows servers with NCPA, how is the data in the API populated? What exactly is the data collection method at the lowest level on the remote server?
meganwilliford
Re: NCPA API Method of Data Collection
One more related question, if the NCPA Listener and NCPA Passive services are disabled on the remote server would any sort of data collection still be running?
benjaminsmith
Hi Megan,
NCPA is an open-source program, if you'd like, you can review the source code on the GitHub page:
https://github.com/NagiosEnterprises/ncpa
The NCPA API uses python modules like psutil to query system information and run the appropriate checks on. The data is saved in a sqlite data for 30 days by default (can be changed in the main ncpa config file).
If you were to stop both the NCPA Listener and NCPA Passive services, nothing would happen and the backend GUI (Flask App) would shutdown.
Hope that helps, let me know if you need clarification on anything.
Benjamin
Benjamin
meganwilliford
Thank you! That is all I was looking for. You can close this thread.
Great!meganwilliford wrote:Thank you! That is all I was looking for. You can close this thread.
Locking thread
