we are trying to monitor the SBC device active calls and SIP truck interface monitoring . We have couple of mib file received from SBC vendor PFA. We have tried to upload couple of mib files and tried but no luck. We need right mib file to achieve this. The below is the link which we downloaded the plugin to monitor. SNMP it enabled from SBC device end also.
https://exchange.nagios.org/directory/P ... cs/details
[root@emea-nagios-a toolsadmin]# ./sbc.py -H XXXX -C XXXX -a
Error in packet
Reason: (noSuchName) There is no such variable name in this MIB.
Failed object: SNMPv2-SMI::enterprises.10950.1.1.6.19.5.0
SBC device snmp not working
Re: SBC device snmp not working
Try modifying the plugin and change this:
To this:
Then test again.
Did you put the Netrake-MIB in /usr/share/snmp/mibs?
https://www.circitor.fr/Mibs/Mib/N/Netrake-MIB.mib
What is the output of this command?
What is the full output of this command?
- Change X.X.X.X to the IP of the SBC, change YOURCOMMUNITY as well
common_options = "-OvQ -v 1"
common_options = "-OvQ -v 2c"
snmptranslate -Tz -m Netrake-MIB
snmpbulkwalk -v 2c -c 'YOURCOMMUNITY' X.X.X.X -m Netrake-MIB netrake
I have changed the plugin and tried but the issue still exist. Also upload the MIB file.
The output of the snmp are attached with the ticket.
[root@emea-nagios-a]# ./sbc.py -H XXXX -C XXXXX -a
Traceback (most recent call last):
File "./sbc.py", line 155, in <module>
main()
File "./sbc.py", line 117, in main
active = get_active_calls(hostname, community, verbose)
File "./sbc.py", line 58, in get_active_calls
return int(value)
ValueError: invalid literal for int() with base 10: 'No Such Object available on this agent at this OID'
You have new mail in /var/spool/mail/root
[root@nagios-a]# snmpbulkwalk -v 2c -c 'XXXXX' XXXX -m Netrake-MIB netrake
Netrake-MIB::netrake = No Such Object available on this agent at this OID
main()
return int(value)
What is the exact make/model of the device you are trying to query?
Based on this output:
That indicates your remote device is not serving the OIDs in question and is likely has SNMP misconfigured on the remote device (you'll need to contact your hardware vendor and ask them if there are any additional steps to enable access to those OIDs) or the device that you are querying does not support the OIDs you're expecting it to.
The below is the device details.
Vendor: AudioCodes
Model: Mediant 800C
Vendor: AudioCodes
Model: Mediant 800C
See the supported MIBs section on page 4:
https://www.audiocodes.com/media/14595/ ... ver-72.pdf
The plugin you found will not work for your device. I was unable to find a plugin that does support it.
I found this as well:
https://www.audiocodes.com/media/13252/ ... ver-72.pdf
You may want to reach out to your vendor and ask them if you can monitor those details (and what the OIDs are for them) for your model.
