MRTG Permission Denied
shoreypu
Post by shoreypu »
Our systems team alerted me to the following error this morning after we upgraded our test server to XI v5.75
2020-12-17 10:30:01: ERROR: Creating templock /var/lib/mrtg/mrtg.lock_38677: Permission denied at /usr/bin/mrtg line 1962.
Here is the cron job that were running:
/5 * * * * root LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg --lock-file /var/lib/mrtg/mrtg.lock --confcache-file /var/lib/mrtg/mrtg.ok --user=nagios --group=nagios
I checked our prod box, which sends errors to a log file and were are seeing the same errors. Were still running XI v5.6.13 in production.
Has anyone else run into this problem? Any help on this is greatly appreciated.
Thanks...John
vtrac
Re: MRTG Permission Denied
Post by vtrac »
Hi shoreypu,
1) Please make sure that user "nagios" has write permission for folder "/var/lib/mrtg" as show below:
You can run these commands as root/sudo to fix them:
chown -R apache.nagios /var/lib/mrtg
chmod -R 664 /var/lib/mrtg
2) Please make sure to remove the "/var/lib/mrtg/mrtg.lock" file if existed.
I looked at line 1962 of "/usr/bin/mrtg" and looks like it is trying to create a $templock file:
  open(LOCK,">$templock") or die "$NOW: ERROR: Creating templock $templock: $!";
I tested the same command on my Nagios XI using the CLI and also tested by creating a cron job with the exact command and both ran OK.
Also, I checked and my mrtg version is "2.17.4".
Could you please check and see what version of mrtg do you have?
Best Regards,
Vinh
shoreypu
Post by shoreypu »
Vinh,
Thanks for your reply.
I've confirmed the configurations, as written below, are the same on our primary, failover and test servers.
1) I've confirmed that nagios has write permissions. AS you'll see, you recommended 664, were set to 775.
[root@nagiosqa mrtg]# ls -la
total 4
drwxrwxr-x 2 apache nagios 20 Dec 18 15:45 .
drwxr-xr-x. 42 root root 4096 Dec 4 08:05 ..
-rwxrwxr-x 1 apache nagios 0 Dec 18 15:45 mrtg.ok
2) As you see above,the lock file does not exist.
3) I've confirmed that line 1962 of "/usr/bin/mrtg: is trying to create a $templock file:
I also verified that mrtg version is 2.17.4
Thanks...John
vtrac
Post by vtrac »
Hi John,
Have you try re-ran the cron job again?
If it is still failing, then could you please try logging in as "nagios" and try create a new file under the "/var/lib/mrtg/" folder as user "nagios".
Regards,
Vinh
shoreypu
Post by shoreypu »
So the cron job runs every five minutes. I did go in to try and run the job earlier and it ran without error, though I did not see a lock file. I then check the log where I'm outputing errors and there were no errors as of this morning at 1am. Then the errors started again at 10am, which was after I tried my tests. Here's some of the log output.
2020-12-21 00:45:02: ERROR: Creating templock /var/lib/mrtg/mrtg.lock_119498: Permission denied at /usr/bin/mrtg line 1962.
2020-12-21 00:50:01: ERROR: Creating templock /var/lib/mrtg/mrtg.lock_121834: Permission denied at /usr/bin/mrtg line 1962.
2020-12-21 00:55:01: ERROR: Creating templock /var/lib/mrtg/mrtg.lock_123884: Permission denied at /usr/bin/mrtg line 1962.
2020-12-21 01:00:02: ERROR: Creating templock /var/lib/mrtg/mrtg.lock_125873: Permission denied at /usr/bin/mrtg line 1962.
2020-12-21 10:00:01: ERROR: Creating templock /var/lib/mrtg/mrtg.lock_91103: Permission denied at /usr/bin/mrtg line 1962.
2020-12-21 10:05:01: ERROR: Creating templock /var/lib/mrtg/mrtg.lock_93148: Permission denied at /usr/bin/mrtg line 1962.
2020-12-21 10:10:01: ERROR: Creating templock /var/lib/mrtg/mrtg.lock_95187: Permission denied at /usr/bin/mrtg line 1962.
2020-12-21 10:15:01: ERROR: Creating templock /var/lib/mrtg/mrtg.lock_97212: Permission denied at /usr/bin/mrtg line 1962.
vtrac
Post by vtrac »
Hi John,
The error said you don't have permission to create the "lock" file under "/var/lib/mrtg".
let restart crond:
# systemctl restart crond
Can you please try as "nagios", create a empty file under "/var/lib/mrtg":
# su - nagios
# echo "" > /var/lib/mrtg/test.out
The cron job is called "mrtg", let try changing the "lock" file location to "/tmp":
# vi /etc/cron.d/mrtg
*/5 * * * * root LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg --lock-file /tmp/mrtg.lock --confcache-file /var/lib/mrtg/mrtg.ok --user=nagios --group=nagios
Please update the results if moving the "lock" file to "/tmp" solve the issue or not.
Regards,
Vinh
shoreypu
Post by shoreypu »
Vinh,
As nagios, I was able to write /var/lib/mrtg/test.out.
I then changed the lock file location in the cron job to /tmp/mrtg.lock. Since then, the error has not returned. I also do not see a lock file in /tmp/. I assume there should be a lock file there, correct?
Thanks...John
vtrac
Post by vtrac »
Hi John,
Great!! .... so moving the lock file to "/tmp" works.
Let keep its there then.
As to the lock file, its should be removed once the mrtg ran is completed each time.
The reason for the lock file is to prevent two mrtg(s) run at the same time.
Regards,
Vinh
shoreypu
Post by shoreypu »
Vinh,
This did seem to work for a bit, but now that I'm back to work, I'm seeing a new error. There's no timestamp, so I'm showing you the previous line, which reflects the last date of the error we resolved.
2020-12-23 13:20:01: ERROR: Creating templock /var/lib/mrtg/mrtg.lock_80688: Permission denied at /usr/bin/mrtg line 1962.
ERROR: writing /var/lib/mrtg/mrtg.ok.ok: Permission denied at /usr/bin/../lib/mrtg2/MRTG_lib.pm line 1630.
John
vtrac
Post by vtrac »
Hi John,
The error you were getting seems like your mrtg's cron job were not able to create the "mrtg.ok" file after it is completed.
Please make sure "nagios" do have "write" permission under "/var/lib/mrtg" folder.
Can you please run the below command and upload the results:
# ls -la /var/lib/mrtg
Do you know if there are TWO mrtg jobs scheduled to run every 5 minutes?
# ls -l /etc/cron.d/
Also, let's try moving the "mrtg.ok" file to "/tmp" as well:
*/5 * * * * root LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg --lock-file /tmp/mrtg.lock --confcache-file /tmp/mrtg.ok --user=nagios --group=nagios
Regards,
Vinh
