Windows Service Monitoring Error
dsilvero
Post by dsilvero »
Hi guys, I lookng for a solution for this issue with windows service monitoring, I have Nagios XI and I monitoring many windows services of this server, with this command: $USER1$/check_nt -H $HOSTADDRESS$ -p 12489 -v $ARG1$ $ARG2$ and everything work ok.
But, when I try to monitor the windows services names: PISqlDas.RTQP
Give me this error: (Return code of 127 is out of bounds. Check if plugin exists)
I capture the config screen and paste the $ARG2$ content:
-d SHOWALL -l "$SERVICEDESC$" ;PISqlDas.RTQP=started
The problem is the dot in service name ? , how I can bypass this error ?
Thanks very much in advance
Diego
vtrac
Re: Windows Service Monitoring Error
Post by vtrac »
Hi Diego,
After doing some research and testing, looks like the error you were getting might be related to not having NSClient installed on your remote Windows server.
Here are example of my tests, checking if services are running (Started or Stopped) on my remote windows which have NSClient service (nscp) running:
# ./check_nt -H 192.168.254.80 -p 12489 -s 'myPASS' -v SERVICESTATE -d SHOWALL  -l http
 http: Started
# ./check_nt -H 192.168.254.80 -p 12489 -s 'myPASS' -v SERVICESTATE -d SHOWALL  -l nscp
 nscp: Started
# ./check_nt -H 192.168.254.80 -p 12489 -s 'myPASS' -v SERVICESTATE -d SHOWALL  -l captureservice
 captureservice: Stopped
However, when I checked for service "PISqlDas.RTQP", which I don't have .... my error is "service not exist":
# ./check_nt -H 192.168.254.80 -p 12489 -s 'myPASS' -v SERVICESTATE -d SHOWALL  -l PISqlDas.RTQP
 Failed to open service PISqlDas.RTQP: 424: The specified service does not exist as an installed service.
So, looks like you need to install NSClient on your remote Windows for "check_nt" to works.
Here are instructions on how to install and configure NSClient agent:
Best Regards,
Vinh
dsilvero
Post by dsilvero »
Thank you Vinh for you help, in this server the nsclient was installed and working fine, I put here an capture of this server monitoring services to see that the only service monitoring that not working is PISqlDas.RTQP(in this case you can see the service description), and all anothers services monitoring are working fine
Thank you very much !!!
ssax
Dreams In Code
Post by ssax »
Please edit the failing service and change the $ARG1$ from this:
To this:
Then save, apply configuration, and force a check.
dsilvero
Post by dsilvero »
Thank you Ssax for you reply, I modified the $ARG02$ (not $ARG01$), but the services name contain illegal characters like:
PI SQL Data Access Server (RTQP Engine)
and give me error, how can I bypass this error ?
Thank you for you patience
Diego
cdienger
Post by cdienger »
Can you provide a screenshot of the error?
Also, what version of XI is this? Some versions the "Run check command" button will produce an error, but if you look at the status of the service in the dashboard it will show up correctly. Please check this.
ssax
Dreams In Code
Post by ssax »
Are you referring to the XI CCM service description containing special chars or the $ARG2$ value?
If the service description, I'd recommend you remove the parens () from the service description but given the way you have it setup to use the own services $SERVICEDESC$ you'll likely need to do this:
Edit /usr/local/nagios/etc/nagios.cfg and change this:
To this:
illegal_object_name_chars=`~!$%^&*|'"<>?,=
Then restart the nagios service.
systemctl restart nagios
Then apply configuration.
dsilvero
Post by dsilvero »
Hi Ssax, I delete () from /usr/local/nagios/etc/nagios.cfg in
and restart Nagios Service
But, when I put () in service description, still show me an error, any idea ?
vtrac
Post by vtrac »
Hi Diego,
Could you please show me the "Service Name" and "Display Name" of this running service?
Open "Task Manager" > Services > "PI SQL Data Access Server" > right click "Open Services" > right click "Properties" of "PI SQL Data Access Server"
Here's an example of "AppRediness":
I have tested and you can use either "Server Name" or "Display Name" with the "-l" option (example):
[root@vt-nagiosxi-62 libexec]# ./check_nt -H 192.168.254.102 -p 12489 -s 'VT9900' -v SERVICESTATE -d SHOWALL  -l AppReadiness
AppReadiness: Stopped
[root@vt-nagiosxi-62 libexec]# ./check_nt -H 192.168.254.102 -p 12489 -s 'VT9900' -v SERVICESTATE -d SHOWALL  -l "App Readiness"
App Readiness: Stopped
I am thinking we can "rename" the PI SQL service name, if needed to.
Regards,
Vinh
dsilvero
Post by dsilvero »
Hi Vtrac, I send you the capture with detail of the service
I run the command:
[xxxxxx libexec]$ ./check_nt -H PARCCVWPIEDA01 -p 12489 -s 'VT9900' -v SERVICESTATE -d SHOWALL -l PI SQL Data Access Server (RTQP Engine)
bash: syntax error near unexpected token `('
Here I put with " " in the service description and give me this error, my nsclient don´t have an password:
[xxxxxx libexec]$ ./check_nt -H PARCCVWPIEDA01 -p 12489 -s 'VT9900' -v SERVICESTATE -d SHOWALL -l "PI SQL Data Access Server (RTQP Engine)"
NSClient - ERROR: Invalid password.
Thank you very much !!!!
