Extract data from Nagios
RebeccaIlene
Post by RebeccaIlene »
Hi Team,
Is there a way we can extract the critical and warning thresholds for all services for each server in Nagios?
cdienger
Re: Extract data from Nagios
Post by cdienger »
Export the configuration using the API and you can grep for some key lines. For example:
curl -XGET "https://xi_ip/nagiosxi/api/v1/config/service?apikey=api_key&pretty=1" | grep 'config_name\|service_description\|check_command'
This info can also be found in /usr/local/nagios/var/objects.cache.
