Import servives from existing Nagios XI?
Is it possible to just export the services from one nagios xi host and import them into another? I don't want the hosts, just the services.
Re: Import servives from existing Nagios XI?
In order for them to run you will need to attach hosts to the services, but yes, you could use the import tool
http://library.nagios.com/library/produ ... -prep-tool
Again, be aware you will need to attach the services to hosts for them to work...
