NDO-3 query failed after each apply configuration
PeterDK
Post by PeterDK »
everytime we apply our configuration we see a lot of the following log entries:
[1611240271] NDO-3: The following query failed while MySQL appears to be connected:
[1611240271] NDO-3: INSERT INTO nagios_scheduleddowntime (instance_id, downtime_type, object_id, entry_time, author_name, comment_data, internal_downtime_id, triggered_by_id, is_fixed, duration, scheduled_start_time, scheduled_end_time) VALUES (1,1,63030,FROM_UNIXTIME(1554368169),'my-author_name','my-comment_data',915511,0,1,-1778430201,FROM_UNIXTIME(1554368106),FROM_UNIXTIME(-224062095)) ON DUPLICATE KEY UPDATE instance_id = VALUES(instance_id), downtime_type = VALUES(downtime_type), object_id = VALUES(object_id), entry_time = VALUES(entry_time), author_name = VALUES(author_name), comment_data = VALUES(comment_data), internal_downtime_id = VALUES(internal_downtime_id), triggered_by_id = VALUES(triggered_by_id), is_fixed = VALUES(is_fixed), duration = VALUES(duration), scheduled_start_time = VALUES(scheduled_start_time), scheduled_end_time = VALUES(scheduled_end_time)
[1611240271] NDO-3: INSERT INTO nagios_downtimehistory (instance_id, downtime_type, object_id, entry_time, author_name, comment_data, internal_downtime_id, triggered_by_id, is_fixed, duration, scheduled_start_time, scheduled_end_time) VALUES (1,1,63030,FROM_UNIXTIME(1554368169),'my-author_name','my-comment_data',915511,0,1,-1778430201,FROM_UNIXTIME(1554368106),FROM_UNIXTIME(-224062095)) ON DUPLICATE KEY UPDATE instance_id = VALUES(instance_id), downtime_type = VALUES(downtime_type), object_id = VALUES(object_id), entry_time = VALUES(entry_time), author_name = VALUES(author_name), comment_data = VALUES(comment_data), internal_downtime_id = VALUES(internal_downtime_id), triggered_by_id = VALUES(triggered_by_id), is_fixed = VALUES(is_fixed), duration = VALUES(duration), scheduled_start_time = VALUES(scheduled_start_time), scheduled_end_time = VALUES(scheduled_end_time)
So, the same entry, one for nagios_scheduleddowntime and one for nagios_downtimehistory.
But I can't find these entries anymore in NagiosXI + those object ID's don't even exist anymore.
The author and comments are valid and I recognise them from something in the past, but they are gone.
I think the issue we have here is that the scheduled_end_time is a negative value.
But the main question is, where does this come from.
I already looked in the cfg file and database tables for orphaned entries or something like that.
I've also looked at this kb article https://support.nagios.com/kb/article/n ... n-822.html
But I don't see the error, it just ends with:
[1611240271] NDO-3: Ended event_handler thread
[1611240284] NDO-3: Ended service_check thread
[1611240296] NDO-3: Ended timed_event thread
[1611240333] NDO-3: Ended service_status thread
[1611240614] NDO-3: Ended downtime thread
Kind regards,
Peter
ssax
Dreams In Code
Re: NDO-3 query failed after each apply configuration
Post by ssax »
What XI version are you running? I would upgrade to the latest if you haven't (XI 5.8.1) there have been some new NDO3 fixes.
Please PM me a copy of your profile, you can download it from Admin > System Profile by clicking the Download Profile button.
If you're unable to generate the the profile through the web interface, please try generating it from the command line by running these commands as root:
rm -rf /usr/local/nagiosxi/var/components/profile*​​
/usr/local/nagiosxi/scripts/components/getprofile.sh SUPPORT
Then send me the resulting /usr/local/nagiosxi/var/components/profile.zip​ file.​
If the profile script fails, please include the ENTIRE output.
jweijters
Post by jweijters »
I just updated to Nagios 5.8.1 and have similar problem, however it already occurs during startup of Nagios
It is also a log entry about query failure it looks like there is a negative value in there: FROM_UNIXTIME(-192526097)
Where does this negative value comes from?
[1611299613] NDO-3: The following query failed while MySQL appears to be connected:
[1611299613] NDO-3: INSERT INTO nagios_scheduleddowntime (instance_id, downtime_type, object_id, entry_time, author_name, comment_data, internal_downtime_id, triggered_by_id, is_fixed, duration, scheduled_start_time, scheduled_end_time) VALUES (1,1,43525,FROM_UNIXTIME(1606744751),'Martijn Stol','Zero is nog niet geinstalleerd',3312,0,1,-1799270792,FROM_UNIXTIME(1606744695),FROM_UNIXTIME(-192526097)) ON DUPLICATE KEY UPDATE instance_id = VALUES(instance_id), downtime_type = VALUES(downtime_type), object_id = VALUES(object_id), entry_time = VALUES(entry_time), author_name = VALUES(author_name), comment_data = VALUES(comment_data), internal_downtime_id = VALUES(internal_downtime_id), triggered_by_id = VALUES(triggered_by_id), is_fixed = VALUES(is_fixed), duration = VALUES(duration), scheduled_start_time = VALUES(scheduled_start_time), scheduled_end_time = VALUES(scheduled_end_time)
[1611299613] NDO-3: INSERT INTO nagios_downtimehistory (instance_id, downtime_type, object_id, entry_time, author_name, comment_data, internal_downtime_id, triggered_by_id, is_fixed, duration, scheduled_start_time, scheduled_end_time) VALUES (1,1,43525,FROM_UNIXTIME(1606744751),'Martijn Stol','Zero is nog niet geinstalleerd',3312,0,1,-1799270792,FROM_UNIXTIME(1606744695),FROM_UNIXTIME(-192526097)) ON DUPLICATE KEY UPDATE instance_id = VALUES(instance_id), downtime_type = VALUES(downtime_type), object_id = VALUES(object_id), entry_time = VALUES(entry_time), author_name = VALUES(author_name), comment_data = VALUES(comment_data), internal_downtime_id = VALUES(internal_downtime_id), triggered_by_id = VALUES(triggered_by_id), is_fixed = VALUES(is_fixed), duration = VALUES(duration), scheduled_start_time = VALUES(scheduled_start_time), scheduled_end_time = VALUES(scheduled_end_time)
[1611299613] NDO-3: INSERT INTO nagios_scheduleddowntime (instance_id, downtime_type, object_id, entry_time, author_name, comment_data, internal_downtime_id, triggered_by_id, is_fixed, duration, scheduled_start_time, scheduled_end_time) VALUES (1,1,43512,FROM_UNIXTIME(1606744776),'Martijn Stol','Zero is nog niet geinstalleerd',3313,0,1,-1799270793,FROM_UNIXTIME(1606744696),FROM_UNIXTIME(-192526097)) ON DUPLICATE KEY UPDATE instance_id = VALUES(instance_id), downtime_type = VALUES(downtime_type), object_id = VALUES(object_id), entry_time = VALUES(entry_time), author_name = VALUES(author_name), comment_data = VALUES(comment_data), internal_downtime_id = VALUES(internal_downtime_id), triggered_by_id = VALUES(triggered_by_id), is_fixed = VALUES(is_fixed), duration = VALUES(duration), scheduled_start_time = VALUES(scheduled_start_time), scheduled_end_time = VALUES(scheduled_end_time)
[1611299613] NDO-3: INSERT INTO nagios_downtimehistory (instance_id, downtime_type, object_id, entry_time, author_name, comment_data, internal_downtime_id, triggered_by_id, is_fixed, duration, scheduled_start_time, scheduled_end_time) VALUES (1,1,43512,FROM_UNIXTIME(1606744776),'Martijn Stol','Zero is nog niet geinstalleerd',3313,0,1,-1799270793,FROM_UNIXTIME(1606744696),FROM_UNIXTIME(-192526097)) ON DUPLICATE KEY UPDATE instance_id = VALUES(instance_id), downtime_type = VALUES(downtime_type), object_id = VALUES(object_id), entry_time = VALUES(entry_time), author_name = VALUES(author_name), comment_data = VALUES(comment_data), internal_downtime_id = VALUES(internal_downtime_id), triggered_by_id = VALUES(triggered_by_id), is_fixed = VALUES(is_fixed), duration = VALUES(duration), scheduled_start_time = VALUES(scheduled_start_time), scheduled_end_time = VALUES(scheduled_end_time)
[1611299613] NDO-3: INSERT INTO nagios_scheduleddowntime (instance_id, downtime_type, object_id, entry_time, author_name, comment_data, internal_downtime_id, triggered_by_id, is_fixed, duration, scheduled_start_time, scheduled_end_time) VALUES (1,1,43490,FROM_UNIXTIME(1606744800),'Martijn Stol','Zerto is nog niet geinstalleerd',3314,0,1,-1799270799,FROM_UNIXTIME(1606744702),FROM_UNIXTIME(-192526097)) ON DUPLICATE KEY UPDATE instance_id = VALUES(instance_id), downtime_type = VALUES(downtime_type), object_id = VALUES(object_id), entry_time = VALUES(entry_time), author_name = VALUES(author_name), comment_data = VALUES(comment_data), internal_downtime_id = VALUES(internal_downtime_id), triggered_by_id = VALUES(triggered_by_id), is_fixed = VALUES(is_fixed), duration = VALUES(duration), scheduled_start_time = VALUES(scheduled_start_time), scheduled_end_time = VALUES(scheduled_end_time)
[1611299613] NDO-3: INSERT INTO nagios_downtimehistory (instance_id, downtime_type, object_id, entry_time, author_name, comment_data, internal_downtime_id, triggered_by_id, is_fixed, duration, scheduled_start_time, scheduled_end_time) VALUES (1,1,43490,FROM_UNIXTIME(1606744800),'Martijn Stol','Zerto is nog niet geinstalleerd',3314,0,1,-1799270799,FROM_UNIXTIME(1606744702),FROM_UNIXTIME(-192526097)) ON DUPLICATE KEY UPDATE instance_id = VALUES(instance_id), downtime_type = VALUES(downtime_type), object_id = VALUES(object_id), entry_time = VALUES(entry_time), author_name = VALUES(author_name), comment_data = VALUES(comment_data), internal_downtime_id = VALUES(internal_downtime_id), triggered_by_id = VALUES(triggered_by_id), is_fixed = VALUES(is_fixed), duration = VALUES(duration), scheduled_start_time = VALUES(scheduled_start_time), scheduled_end_time = VALUES(scheduled_end_time)
[1611299613] NDO-3: INSERT INTO nagios_scheduleddowntime (instance_id, downtime_type, object_id, entry_time, author_name, comment_data, internal_downtime_id, triggered_by_id, is_fixed, duration, scheduled_start_time, scheduled_end_time) VALUES (1,1,43462,FROM_UNIXTIME(1606744821),'Martijn Stol','Zerto is nog niet geinstalleerd',3315,0,1,-1799270800,FROM_UNIXTIME(1606744703),FROM_UNIXTIME(-192526097)) ON DUPLICATE KEY UPDATE instance_id = VALUES(instance_id), downtime_type = VALUES(downtime_type), object_id = VALUES(object_id), entry_time = VALUES(entry_time), author_name = VALUES(author_name), comment_data = VALUES(comment_data), internal_downtime_id = VALUES(internal_downtime_id), triggered_by_id = VALUES(triggered_by_id), is_fixed = VALUES(is_fixed), duration = VALUES(duration), scheduled_start_time = VALUES(scheduled_start_time), scheduled_end_time = VALUES(scheduled_end_time)
[1611299613] NDO-3: INSERT INTO nagios_downtimehistory (instance_id, downtime_type, object_id, entry_time, author_name, comment_data, internal_downtime_id, triggered_by_id, is_fixed, duration, scheduled_start_time, scheduled_end_time) VALUES (1,1,43462,FROM_UNIXTIME(1606744821),'Martijn Stol','Zerto is nog niet geinstalleerd',3315,0,1,-1799270800,FROM_UNIXTIME(1606744703),FROM_UNIXTIME(-192526097)) ON DUPLICATE KEY UPDATE instance_id = VALUES(instance_id), downtime_type = VALUES(downtime_type), object_id = VALUES(object_id), entry_time = VALUES(entry_time), author_name = VALUES(author_name), comment_data = VALUES(comment_data), internal_downtime_id = VALUES(internal_downtime_id), triggered_by_id = VALUES(triggered_by_id), is_fixed = VALUES(is_fixed), duration = VALUES(duration), scheduled_start_time = VALUES(scheduled_start_time), scheduled_end_time = VALUES(scheduled_end_time)
[1611299613] NDO-3: Ended acknowledgement thread
[1611299613] NDO-3: Ended flapping thread
[1611299613] NDO-3: Ended notification thread
[1611299613] Caught SIGSEGV, shutting down...
And then Nagios just stops.
Kind regards,
Joris Weijters
WillemDH
Post by WillemDH »
@ssax PeterDK is a colleague of me and is unavailable today. We are running 5.8.1. Sent you a PM with our system profile.
Nagios XI 5.8.1
https://outsideit.net
jweijters
Post by jweijters »
jweijters wrote:I just updated to Nagios 5.8.1 and have similar problem, however it already occurs during startup of Nagios
Kind regards,
Joris Weijters
I ran a repair database. This fixed the crashing Nagios, however the insert still fails.
Where is this query intiated from?
kind regards,
Joris Weijters
WillemDH
Post by WillemDH »
@ssax @jweijters
The nagios process on our Nagios production servers also just crashed :(
Jan 22 11:13:54 nagiosserver nagios[5964]: Caught SIGSEGV, shutting down...
The weird things is that the Nagios service seem to be still running, but the nagios process is killed / unexistant..
The exact same thing also happened wednessday evening, but we were hoping that it was a one-time thing. Apparently not.. :(
Both times the nagios process crash happened about exact 2 minutes after an apply configuration. (There were multiple other apply configurations where the nagios process did not crash)
Already gone through the core / audit logs looking for something that could explain the process kill, but found absolutely nothing. Out mysqldb should not be corrupt, as we got a check for that which is not triggering.
Created a zip containing nagios.log and nagios.cfg and PM'ed it to you Sean.
Please advice how to continue.
Grtz
Willem
Nagios XI 5.8.1
jweijters
Post by jweijters »
@WillenDH,
After the database repair, Nagios keeps running, The database repaire fixed al lot of indexes
I also found that the default value for the tables have been changed.
it looks like the negative date values comes from dates entered during setting of the downtime dates after 2038
In the pre-upgrade database these entries were also not available.
Nagios 5.8.1:
Database changed
MariaDB [nagios]> describe nagios_scheduleddowntime;
| Field                  | Type         | Null | Key | Default             | Extra          |
| scheduleddowntime_id   | int(11)      | NO   | PRI | NULL                | auto_increment |
| instance_id            | smallint(6)  | NO   | MUL | 0                   |                |
| downtime_type          | smallint(6)  | NO   |     | 0                   |                |
| object_id              | int(11)      | NO   |     | 0                   |                |
| entry_time             | datetime     | NO   |     | 1970-01-01 00:00:01 |                |
| author_name            | varchar(64)  | NO   |     |                     |                |
| comment_data           | varchar(255) | NO   |     |                     |                |
| internal_downtime_id   | int(11)      | NO   |     | 0                   |                |
| triggered_by_id        | int(11)      | NO   |     | 0                   |                |
| is_fixed               | smallint(6)  | NO   |     | 0                   |                |
| duration               | int(11)      | NO   |     | 0                   |                |
| scheduled_start_time   | datetime     | NO   |     | 1970-01-01 00:00:01 |                |
| scheduled_end_time     | datetime     | NO   |     | 1970-01-01 00:00:01 |                |
| was_started            | smallint(6)  | NO   |     | 0                   |                |
| actual_start_time      | datetime     | NO   |     | 1970-01-01 00:00:01 |                |
| actual_start_time_usec | int(11)      | NO   |     | 0                   |                |
16 rows in set (0.00 sec)
Nagios 5.6.14:
| entry_time             | datetime     | NO   |     | 0000-00-00 00:00:00 |                |
| scheduled_start_time   | datetime     | NO   |     | 0000-00-00 00:00:00 |                |
| scheduled_end_time     | datetime     | NO   |     | 0000-00-00 00:00:00 |                |
| actual_start_time      | datetime     | NO   |     | 0000-00-00 00:00:00 |                |
WillemDH
Post by WillemDH »
@jweijters,
Ok, thanks for the suggestion. Did the mysql repair and rebooted the server..
DATABASE: nagios
TABLE:
/var/lib/mysql/nagios /home/myuser@mydomain
- recovering (with sort) MyISAM-table 'nagios_acknowledgements'
Data records: 42309
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_commands'
Data records: 448
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_commenthistory'
Data records: 2384919
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_comments'
Data records: 177
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_configfiles'
Data records: 1
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_configfilevariables'
Data records: 133
- Fixing index 1
- recovering (with sort) MyISAM-table 'nagios_conninfo'
Data records: 20036
- Fixing index 1
- recovering (with sort) MyISAM-table 'nagios_contact_addresses'
Data records: 216
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_contactgroup_members'
Data records: 237
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_contactgroups'
Data records: 23
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_contact_notificationcommands'
Data records: 420
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_contactnotificationmethods'
Data records: 166660
- Fixing index 1
- Fixing index 2
- Fixing index 3
- Fixing index 4
- recovering (with sort) MyISAM-table 'nagios_contactnotifications'
Data records: 166565
- Fixing index 1
- Fixing index 2
- Fixing index 3
- Fixing index 4
- Fixing index 5
- recovering (with sort) MyISAM-table 'nagios_contacts'
Data records: 210
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_contactstatus'
Data records: 210
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_customvariables'
Data records: 4699
- Fixing index 1
- Fixing index 2
- Fixing index 3
- recovering (with sort) MyISAM-table 'nagios_customvariablestatus'
Data records: 4699
- Fixing index 1
- Fixing index 2
- Fixing index 3
- recovering (with keycache) MyISAM-table 'nagios_dbversion'
Data records: 1
- recovering (with sort) MyISAM-table 'nagios_downtimehistory'
Data records: 435117
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_eventhandlers'
Data records: 101
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_externalcommands'
Data records: 24646
- Fixing index 1
- recovering (with sort) MyISAM-table 'nagios_flappinghistory'
Data records: 285789
- Fixing index 1
- recovering (with sort) MyISAM-table 'nagios_hostchecks'
Data records: 4024
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_host_contactgroups'
Data records: 2668
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_host_contacts'
Data records: 5661
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_hostdependencies'
Data records: 0
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_hostescalation_contactgroups'
Data records: 0
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_hostescalation_contacts'
Data records: 0
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_hostescalations'
Data records: 0
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_hostgroup_members'
Data records: 10812
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_hostgroups'
Data records: 320
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_host_parenthosts'
Data records: 16
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_hosts'
Data records: 2406
- Fixing index 1
- Fixing index 2
- Fixing index 3
- recovering (with sort) MyISAM-table 'nagios_hoststatus'
Data records: 2406
- Fixing index 1
- Fixing index 2
- Fixing index 3
- Fixing index 4
- Fixing index 5
- Fixing index 6
- Fixing index 7
- Fixing index 8
- Fixing index 9
- Fixing index 10
- Fixing index 11
- Fixing index 12
- Fixing index 13
- Fixing index 14
- Fixing index 15
- Fixing index 16
- Fixing index 17
- Fixing index 18
- Fixing index 19
- recovering (with sort) MyISAM-table 'nagios_instances'
Data records: 1
- Fixing index 1
- recovering (with sort) MyISAM-table 'nagios_logentries'
Data records: 3307106
- Fixing index 1
- Fixing index 2
- Fixing index 3
- Fixing index 4
- Fixing index 5
- recovering (with sort) MyISAM-table 'nagios_notifications'
Data records: 205262
- Fixing index 1
- Fixing index 2
- Fixing index 3
- Fixing index 4
- Fixing index 5
- recovering (with sort) MyISAM-table 'nagios_objects'
Data records: 80151
- Fixing index 1
- Fixing index 2
- Fixing index 3
- Fixing index 4
- Fixing index 5
- recovering (with sort) MyISAM-table 'nagios_processevents'
Data records: 11452
- Fixing index 1
- recovering (with sort) MyISAM-table 'nagios_programstatus'
Data records: 1
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_runtimevariables'
Data records: 17
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_scheduleddowntime'
Data records: 416
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_servicechecks'
Data records: 48382
- Fixing index 1
- Fixing index 2
- Fixing index 3
- Fixing index 4
- recovering (with sort) MyISAM-table 'nagios_service_contactgroups'
Data records: 19367
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_service_contacts'
Data records: 20953
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_servicedependencies'
Data records: 0
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_serviceescalation_contactgroups'
Data records: 0
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_serviceescalation_contacts'
Data records: 0
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_serviceescalations'
Data records: 0
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_servicegroup_members'
Data records: 28632
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_servicegroups'
Data records: 122
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_service_parentservices'
Data records: 0
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_services'
Data records: 18367
- Fixing index 1
- Fixing index 2
- Fixing index 3
- recovering (with sort) MyISAM-table 'nagios_servicestatus'
Data records: 18367
- Fixing index 1
- Fixing index 2
- Fixing index 3
- Fixing index 4
- Fixing index 5
- Fixing index 6
- Fixing index 7
- Fixing index 8
- Fixing index 9
- Fixing index 10
- Fixing index 11
- Fixing index 12
- Fixing index 13
- Fixing index 14
- Fixing index 15
- Fixing index 16
- Fixing index 17
- Fixing index 18
- Fixing index 19
- recovering (with sort) MyISAM-table 'nagios_statehistory'
Data records: 6753187
- Fixing index 1
- Fixing index 2
- Fixing index 3
- recovering (with sort) MyISAM-table 'nagios_systemcommands'
Data records: 140
- Fixing index 1
- Fixing index 2
- Fixing index 3
- recovering (with sort) MyISAM-table 'nagios_timedeventqueue'
Data records: 0
- Fixing index 1
- Fixing index 2
- Fixing index 3
- Fixing index 4
- Fixing index 5
- Fixing index 6
- recovering (with sort) MyISAM-table 'nagios_timedevents'
Data records: 0
- Fixing index 1
- Fixing index 2
- Fixing index 3
- Fixing index 4
- Fixing index 5
- Fixing index 6
- recovering (with sort) MyISAM-table 'nagios_timeperiods'
Data records: 222
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_timeperiod_timeranges'
Data records: 1523
- Fixing index 1
- Fixing index 2
REPAIR COMPLETE
DATABASE: nagiosql
TABLE:
/var/lib/mysql/nagiosql /home/myuser@mydomain
- recovering (with sort) MyISAM-table 'tbl_command'
Data records: 455
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'tbl_contactgroup'
Data records: 25
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'tbl_contact'
Data records: 210
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'tbl_contacttemplate'
Data records: 3
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'tbl_domain'
Data records: 1
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'tbl_hostdependency'
Data records: 0
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'tbl_hostescalation'
Data records: 0
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'tbl_hostextinfo'
Data records: 0
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'tbl_hostgroup'
Data records: 333
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'tbl_host'
Data records: 2438
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'tbl_hosttemplate'
Data records: 99
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'tbl_info'
Data records: 218
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'tbl_lnkContactgroupToContactgroup'
Data records: 4
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkContactgroupToContact'
Data records: 7
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkContacttemplateToCommandHost'
Data records: 3
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkContacttemplateToCommandService'
Data records: 3
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkContacttemplateToContactgroup'
Data records: 2
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkContacttemplateToContacttemplate'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkContacttemplateToVariabledefinition'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkContactToCommandHost'
Data records: 13
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkContactToCommandService'
Data records: 13
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkContactToContactgroup'
Data records: 37
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkContactToContacttemplate'
Data records: 208
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkContactToVariabledefinition'
Data records: 78
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkHostdependencyToHost_DH'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkHostdependencyToHostgroup_DH'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkHostdependencyToHostgroup_H'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkHostdependencyToHost_H'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkHostescalationToContactgroup'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkHostescalationToContact'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkHostescalationToHostgroup'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkHostescalationToHost'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkHostgroupToHostgroup'
Data records: 125
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkHostgroupToHost'
Data records: 272
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkHosttemplateToContactgroup'
Data records: 7
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkHosttemplateToContact'
Data records: 27
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkHosttemplateToHostgroup'
Data records: 23
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkHosttemplateToHost'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkHosttemplateToHosttemplate'
Data records: 60
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkHosttemplateToVariabledefinition'
Data records: 3
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkHostToContactgroup'
Data records: 2678
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkHostToContact'
Data records: 5535
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkHostToHostgroup'
Data records: 7799
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkHostToHost'
Data records: 16
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkHostToHosttemplate'
Data records: 2419
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkHostToVariabledefinition'
Data records: 297
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServicedependencyToHost_DH'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServicedependencyToHostgroup_DH'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServicedependencyToHostgroup_H'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServicedependencyToHost_H'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServicedependencyToService_DS'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServicedependencyToService_S'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServiceescalationToContactgroup'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServiceescalationToContact'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServiceescalationToHostgroup'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServiceescalationToHost'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServiceescalationToService'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServicegroupToServicegroup'
Data records: 17
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServicegroupToService'
Data records: 302
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServicetemplateToContactgroup'
Data records: 21
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServicetemplateToContact'
Data records: 264
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServicetemplateToHostgroup'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServicetemplateToHost'
Data records: 3
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServicetemplateToServicegroup'
Data records: 473
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServicetemplateToServicetemplate'
Data records: 97
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServicetemplateToVariabledefinition'
Data records: 4
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServiceToContactgroup'
Data records: 17908
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServiceToContact'
Data records: 18495
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServiceToHostgroup'
Data records: 6
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServiceToHost'
Data records: 18629
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServiceToServicegroup'
Data records: 10193
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServiceToServicetemplate'
Data records: 17601
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServiceToVariabledefinition'
Data records: 4465
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkTimeperiodToTimeperiod'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_logbook'
Data records: 93
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_mainmenu'
Data records: 7
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_servicedependency'
Data records: 0
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'tbl_serviceescalation'
Data records: 0
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'tbl_serviceextinfo'
Data records: 0
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'tbl_servicegroup'
Data records: 124
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'tbl_service'
Data records: 18631
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_servicetemplate'
Data records: 554
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'tbl_session_locks'
Data records: 4
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_session'
Data records: 4
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_settings'
Data records: 13
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'tbl_submenu'
Data records: 29
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_timedefinition'
Data records: 1537
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_timeperiod'
Data records: 224
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'tbl_user'
Data records: 2
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'tbl_variabledefinition'
Data records: 8885
- Fixing index 1
REPAIR COMPLETE
DATABASE: nagiosxi
TABLE:
/var/lib/mysql/nagiosxi /home/myuser@mydomain
- recovering (with sort) MyISAM-table 'xi_auditlog'
Data records: 33925
- Fixing index 1
- Fixing index 2
- Fixing index 3
- Fixing index 4
- Fixing index 5
- recovering (with sort) MyISAM-table 'xi_auth_tokens'
Data records: 3546
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'xi_cmp_trapdata_log'
Data records: 0
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'xi_cmp_trapdata'
Data records: 201
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'xi_commands'
Data records: 76
- Fixing index 1
- recovering (with sort) MyISAM-table 'xi_eventqueue'
Data records: 1
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'xi_events'
Data records: 5132
- Fixing index 1
- Fixing index 2
- Fixing index 3
- recovering (with sort) MyISAM-table 'xi_incidents'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'xi_meta'
Data records: 5138
- Fixing index 1
- recovering (with sort) MyISAM-table 'xi_options'
Data records: 438
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'xi_sessions'
Data records: 3
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'xi_sysstat'
Data records: 17
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'xi_usermeta'
Data records: 10171
- Fixing index 1
- Fixing index 2
- Fixing index 3
- recovering (with sort) MyISAM-table 'xi_users'
Data records: 195
- Fixing index 1
- Fixing index 2
REPAIR COMPLETE
nagios database repair succeeded
nagiosql database repair succeeded
nagiosxi database repair succeeded
Unfortunately after the repair and reboot the nagios process crashed again...
Also, I still see 100's of query failed errors after applying:
[1611318543] NDO-3: The following query failed while MySQL appears to be connected:
[1611318543] NDO-3: INSERT INTO nagios_downtimehistory (instance_id, downtime_type, object_id, entry_time, author_name, comment_data, internal_downtime_id, triggered_by_id, is_fixed, duration, scheduled_start_time, scheduled_end_time) VALUES (1,1,63030,FROM_UNIXTIME(1554368169),'Claeys Stephen','server for citrix PVS golden image',915511,0,1,-1778430201,FROM_UNIXTIME(1554368106),FROM_UNIXTIME(-224062095)) ON DUPLICATE KEY UPDATE instance_id = VALUES(instance_id), downtime_type = VALUES(downtime_type), object_id = VALUES(object_id), entry_time = VALUES(entry_time), author_name = VALUES(author_name), comment_data = VALUES(comment_data), internal_downtime_id = VALUES(internal_downtime_id), triggered_by_id = VALUES(triggered_by_id), is_fixed = VALUES(is_fixed), duration = VALUES(duration), scheduled_start_time = VALUES(scheduled_start_time), scheduled_end_time = VALUES(scheduled_end_time)
[1611318543] NDO-3: Ended event_handler thread
Grtz
Willem
Nagios XI 5.8.1
benjaminsmith
Post by benjaminsmith »
Hi Willem,
I'm going to reach out to the developer of ndo for assistance. It appears to be an issue with setting dates for the downtimes into the future.
Thank you for your patience.
Benjamin
PeterDK
Post by PeterDK »
Hi everyone,
just a small update with a link to another forum thread, which may or may not be related:
https://support.nagios.com/forum/viewto ... 16&t=61378
We are also experiencing higher load of the mysql process and more unstable active checks.
We will review our backup and apply config strategy and follow up after the database repair this morning.
Last step will be downgrading to NDO2 again, I suppose.
Kind regards,
Peter
