updated to the new MSSQL Server Monitoring Wizard 2.03
update to the new MSSQL Server Monitoring Wizard 2.03 and now when I finish every time I get Configuration verification failed
Re: updated to the new MSSQL Server Monitoring Wizard 2.03
tried on my test server and Wizard 2.0.1 works fine
benjaminsmith
Hi @btayl,
On the 2.0.3 server, can you run the following tail command then re-run the wizard and post the full output to the thread. Thanks, Benjmain
tail -f /usr/local/nagiosxi/var/cmdsubsys.log
You can close this one it started working again.
benjaminsmith
Great! Glad it's working for you now.You can close this one it started working again.
