Nagios XI offloaded db size increasing frequently
taashee
Post by taashee »
Hello Team ,
There is one case where nagios db is offloaded onto another server . We recently truncated the tables in nagiosxi and nagios database . But size is increasing again and again resulting nagios is not working properly and often asking for db repair .
For your reference please find the system profile and let us know why size has increased largely .
Moderator's Note: The profile has been shared with the support team but has been removed from the public forum.
benjaminsmith
Re: Nagios XI offloaded db size increasing frequently
Post by benjaminsmith »
Hi @taashee,
There's a database maintenance script that runs as cron job every hour to optimize and trim the tables based on the settings in Admin > System Config > Performance Settings > Databases, make sure the cron service is running on this server.
systemctl status crond
In the apache log, I'm also seeing some connection issues to the database. You may have some network issues disrupting the connection. Do you have issues pinging the server.
 PHP Warning:  mysqli_real_connect(): (HY000/2003): Can't connect to MySQL server on 'ip address of remote db server' (111) in /usr/local/nagiosxi/html/db/adodb/drivers/adodb-mysqli.inc.php on line 125, referer: http://<ipaddress</nagiosxi/includes/components/xicore/status.php?show=hostdetail&host=mow-tableau-db.corp.drreddys.com
Run the following query to list the sizes of the current tables and post it the the thread. Thanks, Benjamin
echo "SELECT table_name AS 'Table', round(((data_length + index_length) / 1024 / 1024), 2) 'Size in MB' FROM information_schema.TABLES WHERE table_schema IN ('nagios', 'nagiosql', 'nagiosxi');" | mysql -h 127.0.0.1 -uroot -pnagiosxi --table
taashee
Post by taashee »
Hello Benjamin ,
Please find the size of the databases .The command you have mentioned is not working but i checked db size otherway .
[root@nagios-db ~]# cd /var/lib/mysql/
[root@nagios-db mysql]# du -hs * | grep G
7.5G nagios
13G nagiosxi
[root@nagios-db mysql]# cd nagios
[root@nagios-db nagios]# du -hs * | grep G
2.0G nagios_logentries.MYD
1.9G nagios_logentries.MYI
1.3G nagios_statehistory.MYD
[root@nagios-db nagios]# cd ../nagiosxi/
[root@nagios-db nagiosxi]# du -hs * | grep G
11G xi_meta.MYD
taashee
Post by taashee »
Hi Benjamin ,
command worked .please find the respective size .
MariaDB [(none)]> SELECT table_name AS 'Table', round(((data_length + index_length) / 1024 / 1024), 2) 'Size in MB' FROM information_schema.TABLES WHERE table_schema IN ('nagios', 'nagiosql', 'nagiosxi');
| Table | Size in MB |
| nagios_acknowledgements | 7.14 |
| nagios_commands | 0.02 |
| nagios_commenthistory | 16.33 |
| nagios_comments | 0.02 |
| nagios_configfiles | 0.00 |
| nagios_configfilevariables | 0.01 |
| nagios_conninfo | 0.74 |
| nagios_contact_addresses | 0.00 |
| nagios_contact_notificationcommands | 0.02 |
| nagios_contactgroup_members | 0.00 |
| nagios_contactgroups | 0.00 |
| nagios_contactnotificationmethods | 3.32 |
| nagios_contactnotifications | 3.62 |
| nagios_contacts | 0.00 |
| nagios_contactstatus | 0.00 |
| nagios_customvariables | 0.73 |
| nagios_customvariablestatus | 0.78 |
| nagios_dbversion | 0.00 |
| nagios_downtimehistory | 5.90 |
| nagios_eventhandlers | 3.52 |
| nagios_externalcommands | 8.07 |
| nagios_flappinghistory | 11.89 |
| nagios_host_contactgroups | 0.00 |
| nagios_host_contacts | 0.06 |
| nagios_host_parenthosts | 0.00 |
| nagios_hostchecks | 0.00 |
| nagios_hostdependencies | 0.00 |
| nagios_hostescalation_contactgroups | 0.00 |
| nagios_hostescalation_contacts | 0.00 |
| nagios_hostescalations | 0.00 |
| nagios_hostgroup_members | 0.05 |
| nagios_hostgroups | 0.01 |
| nagios_hosts | 0.32 |
| nagios_hoststatus | 0.63 |
| nagios_instances | 0.00 |
| nagios_logentries | 2731.56 |
| nagios_notifications | 964.99 |
| nagios_objects | 2.77 |
| nagios_processevents | 0.16 |
| nagios_programstatus | 0.00 |
| nagios_runtimevariables | 0.00 |
| nagios_scheduleddowntime | 0.00 |
| nagios_service_contactgroups | 0.00 |
| nagios_service_contacts | 0.42 |
| nagios_service_parentservices | 0.00 |
| nagios_servicechecks | 0.00 |
| nagios_servicedependencies | 0.00 |
| nagios_serviceescalation_contactgroups | 0.00 |
| nagios_serviceescalation_contacts | 0.00 |
| nagios_serviceescalations | 0.00 |
| nagios_servicegroup_members | 0.01 |
| nagios_servicegroups | 0.00 |
| nagios_services | 1.76 |
| nagios_servicestatus | 4.69 |
| nagios_statehistory | 1630.55 |
| nagios_systemcommands | 0.04 |
| nagios_timedeventqueue | 0.00 |
| nagios_timedevents | 0.00 |
| nagios_timeperiod_timeranges | 0.02 |
| nagios_timeperiods | 0.00 |
| tbl_command | 0.04 |
| tbl_contact | 0.01 |
| tbl_contactgroup | 0.01 |
| tbl_contacttemplate | 0.01 |
| tbl_domain | 0.01 |
| tbl_host | 0.25 |
| tbl_hostdependency | 0.00 |
| tbl_hostescalation | 0.00 |
| tbl_hostextinfo | 0.00 |
| tbl_hostgroup | 0.01 |
| tbl_hosttemplate | 0.02 |
| tbl_info | 0.13 |
| tbl_lnkContactToCommandHost | 0.00 |
| tbl_lnkContactToCommandService | 0.00 |
| tbl_lnkContactToContactgroup | 0.00 |
| tbl_lnkContactToContacttemplate | 0.00 |
| tbl_lnkContactToVariabledefinition | 0.00 |
| tbl_lnkContactgroupToContact | 0.00 |
| tbl_lnkContactgroupToContactgroup | 0.00 |
| tbl_lnkContacttemplateToCommandHost | 0.00 |
| tbl_lnkContacttemplateToCommandService | 0.00 |
| tbl_lnkContacttemplateToContactgroup | 0.00 |
| tbl_lnkContacttemplateToContacttemplate | 0.00 |
| tbl_lnkContacttemplateToVariabledefinition | 0.00 |
| tbl_lnkHostToContact | 0.04 |
| tbl_lnkHostToContactgroup | 0.00 |
| tbl_lnkHostToHost | 0.00 |
| tbl_lnkHostToHostgroup | 0.02 |
| tbl_lnkHostToHosttemplate | 0.04 |
| tbl_lnkHostToVariabledefinition | 0.03 |
| tbl_lnkHostdependencyToHost_DH | 0.00 |
| tbl_lnkHostdependencyToHost_H | 0.00 |
| tbl_lnkHostdependencyToHostgroup_DH | 0.00 |
| tbl_lnkHostdependencyToHostgroup_H | 0.00 |
| tbl_lnkHostescalationToContact | 0.00 |
| tbl_lnkHostescalationToContactgroup | 0.00 |
| tbl_lnkHostescalationToHost | 0.00 |
| tbl_lnkHostescalationToHostgroup | 0.00 |
| tbl_lnkHostgroupToHost | 0.01 |
| tbl_lnkHostgroupToHostgroup | 0.00 |
| tbl_lnkHosttemplateToContact | 0.00 |
| tbl_lnkHosttemplateToContactgroup | 0.00 |
| tbl_lnkHosttemplateToHost | 0.00 |
| tbl_lnkHosttemplateToHostgroup | 0.00 |
| tbl_lnkHosttemplateToHosttemplate | 0.00 |
| tbl_lnkHosttemplateToVariabledefinition | 0.00 |
| tbl_lnkServiceToContact | 0.23 |
| tbl_lnkServiceToContactgroup | 0.00 |
| tbl_lnkServiceToHost | 0.25 |
| tbl_lnkServiceToHostgroup | 0.00 |
| tbl_lnkServiceToServicegroup | 0.00 |
| tbl_lnkServiceToServicetemplate | 0.26 |
| tbl_lnkServiceToVariabledefinition | 0.19 |
| tbl_lnkServicedependencyToHost_DH | 0.00 |
| tbl_lnkServicedependencyToHost_H | 0.00 |
| tbl_lnkServicedependencyToHostgroup_DH | 0.00 |
| tbl_lnkServicedependencyToHostgroup_H | 0.00 |
| tbl_lnkServicedependencyToService_DS | 0.00 |
| tbl_lnkServicedependencyToService_S | 0.00 |
| tbl_lnkServiceescalationToContact | 0.00 |
| tbl_lnkServiceescalationToContactgroup | 0.00 |
| tbl_lnkServiceescalationToHost | 0.00 |
| tbl_lnkServiceescalationToHostgroup | 0.00 |
| tbl_lnkServiceescalationToService | 0.00 |
| tbl_lnkServicegroupToService | 0.01 |
| tbl_lnkServicegroupToServicegroup | 0.00 |
| tbl_lnkServicetemplateToContact | 0.00 |
| tbl_lnkServicetemplateToContactgroup | 0.00 |
| tbl_lnkServicetemplateToHost | 0.00 |
| tbl_lnkServicetemplateToHostgroup | 0.00 |
| tbl_lnkServicetemplateToServicegroup | 0.00 |
| tbl_lnkServicetemplateToServicetemplate | 0.01 |
| tbl_lnkServicetemplateToVariabledefinition | 0.00 |
| tbl_lnkTimeperiodToTimeperiod | 0.00 |
| tbl_logbook | 0.00 |
| tbl_mainmenu | 0.00 |
| tbl_permission | 0.02 |
| tbl_permission_inactive | 0.02 |
| tbl_service | 1.52 |
| tbl_servicedependency | 0.00 |
| tbl_serviceescalation | 0.00 |
| tbl_serviceextinfo | 0.00 |
| tbl_servicegroup | 0.01 |
| tbl_servicetemplate | 0.02 |
| tbl_session | 0.00 |
| tbl_session_locks | 0.00 |
| tbl_settings | 0.00 |
| tbl_submenu | 0.00 |
| tbl_timedefinition | 0.01 |
| tbl_timeperiod | 0.01 |
| tbl_user | 0.01 |
| tbl_variabledefinition | 0.48 |
| xi_auditlog | 1.56 |
| xi_auth_tokens | 0.03 |
| xi_cmp_trapdata | 0.03 |
| xi_cmp_trapdata_log | 0.03 |
| xi_commands | 0.00 |
| xi_eventqueue | 3.81 |
| xi_events | 507.24 |
| xi_incidents | 0.02 |
| xi_meta | 10732.01 |
| xi_options | 0.02 |
| xi_sessions | 0.03 |
| xi_sysstat | 0.01 |
| xi_usermeta | 0.31 |
| xi_users | 0.02 |
166 rows in set (0.02 sec)
ssax
Dreams In Code
Post by ssax »
You are hitting a bug, you will need to truncate these tables to fix it:
mysql -h X.X.X.X -unagiosxi -p'n@gweb' nagiosxi -e "truncate table xi_events; truncate table xi_meta; truncate table xi_eventqueue;"
Or as root:
mysql -h X.X.X.X -uroot -p'nagiosxi' nagiosxi -e "truncate table xi_events; truncate table xi_meta; truncate table xi_eventqueue;"
taashee
Post by taashee »
Hi Benjamin ,
I did as guided by you .
But how you came to know that it is a bug . Can u clarify please .
ssax
Dreams In Code
Post by ssax »
This is a known bug. Those are temporary tables that should be cleaned out automatically by the cron jobs after being processed, if they are large like yours that means you're hitting the bug and it can only be fixed by truncating those temporary tables.
