Plugin to monitor error messages in a log file for windows s
tchandra
Post by tchandra »
Team,
we have a task to monitor error messages in a log file for a application server.
we tried with check_log files plugin and it showing the output OK - no errors or warnings.
But user is saying that jobs failed and threw the error.when we checked the file & found error messages , but Nagios didn't checked the error pattern and still showing status as OK.
can someone please suggest on this
Command defined in custom file :
check_logfiles_AcurityCmore=scripts\check_logfiles.exe --f scripts\etc\check_logfiles.cfg --searches=AcurityCmore
Script :
$seekfilesdir = 'C:\Program Files\NSClient\scripts\var';
$protocolsdir = 'C:\Program Files\NSClient\scripts\var';
$MACROS = { LOGDIR => 'D:\AcurityCmore-JobServer\logs' };
@searches = ({
tag => 'AcurityCmore',
logfile => '$LOGDIR$\service-runner.err.txt',
criticalpatterns => ['AcurityServerDaemonException:','SQLServerException: The connection is closed.'],
options => 'nologfilenocry',
Thanks in advance.
cdienger
Re: Plugin to monitor error messages in a log file for windo
Post by cdienger »
Has this worked previously? My first thought is that the pattern isn't matching, but we would need to see an example of service-runner.err.txt to test that.
Another possibility is that it did work initially, but then subsequent checks would have not returned CRITICAL since the plugin monitors the file and will only scan new log entries on subsequent check attempts.
tchandra
Post by tchandra »
Hi cdienger ,
Thanks for your response.
Anyhow issue got fixed , after editing the script.
Previously, It is checking new entries only.
Regards,
Chandra
cdienger
Post by cdienger »
Thanks for the update!
