Thanks in advance!
I have 2 hosts that have a service each, which are in active / passive mode, in such a way that when it is active in one node, in the other it must be stopped.
To monitor it I have tried a dependency:
define servicedependency {
host_name host1
service_description ServiceA
dependent_host_name host2
dependent_service_description ServiceB
execution_failure_criteria or
notification_failure_criteria or
}Is there any other way to remove the UNKNOWN status from this service when the other is OK?
thanks!
