configure SSL for integration Network Analyzer
amedy caisse
Post by amedy caisse »
O'Que the big problem is SSL configuration .... I can't configure SSL, then the integration API ends up giving errors.
NB:Failed connect to API. Check your connection to the host (using SSL?) and make sure your Nagios Network Analyzer is version 2014R1.5 or higher.
Re: configure SSL for integration Network Analyzer
What is the version of Nagios Network Analyzer that you are currently running? How did you try configuring SSL on your server? Did you follow our official documentation?
https://assets.nagios.com/downloads/nag ... alyzer.pdf
Did you follow all of the steps, outlined in the document listed above?
Where do you see this error? Can you show us a screenshot?
