If a service is in warning or critical it report the Duration incorrectly.
20 minutes shows up as 3 hours 20 minutes.
Service Duration Reports time Plus 3 hours.
Re: Service Duration Reports time Plus 3 hours.
I'm not sure what you mean. Can you post a screenshot that demonstrates this?
Duration
6h 8m 25s
But it has only been
3h 8m 25s
seems to have happen after Daylight Savings Time.
6h 8m 25s
3h 8m 25s
It's unlikely that the bug is due to daylight savings, being as the changeover was more than a week ago.
Has this just started happening that you noticed, or has this been happening a long time with this particular host/service?
Is this a passive or an active check?
What is the time zone for Nagios XI set to? Look under Admin => System Settings -> General.
What is the system time zone set to? (run the "date" command)
What is the PHP time zone set to? (run "grep -i zone /etc/php.ini")
