Hi Team,
We want to monitor AD connect in Nagios XI. I could find below plugin to monitor the same but I am unable to find the the plugin name itself.
Below is the link:
https://exchange.nagios.org/directory/P ... 20%2DHours.
Please suggest some plugins that would be helpful to monitor AD connect sync.
AD Connect monitoring
benjaminsmith
Re: AD Connect monitoring
Hi @kalyanpabolu,
There is a collection for plugins by this member on GitHub. This looks like the plugin you are looking for:
https://github.com/juangranados/nagios- ... ctsync.ps1
--Benjamin
--Benjamin
kalyanpabolu
Thank you for your reply.
I am not sure how to use powershell script in Linux. Could you please guide us on the same?
Please give an example to use the script.
The powershell scripts are meant to be run through an agent such as NCPA that would be running on the remote Windows server, see here:
https://support.nagios.com/kb/article/n ... a-722.html
kalyanpabolu
Thank you for the help!!
We are able to get the correct output using the same plugin but I am getting some additional error message as well.
[root@vmaz-nagiosxi libexec]# /usr/local/nagios/libexec/check_ncpa.py -H 10.44.3.78 -t ******* -P 5693 -M 'plugins/check_azureadconnectsync.ps1'
Get-ADSyncScheduler : The term 'Get-ADSyncScheduler' is not recognized as the
name of a cmdlet, function, script file, or operable program. Check the
spelling of the name, or if a path was included, verify that the path is
correct and try again.
At C:\Program Files (x86)\Nagios\NCPA\plugins\check_azureadconnectsync.ps1:36
char:20
+ $ADSyncScheduler = Get-ADSyncScheduler
+ CategoryInfo : ObjectNotFound: (Get-ADSyncScheduler:String) [],
CommandNotFoundException
+ FullyQualifiedErrorId : CommandNotFoundException
CRITICAL: Azure AD Connect Sync is disabled. Server is in active mode. Latest heart beat event (within last 3 hours). Time 03/25/2021 14:47:50.
Can you please help me on the same?
char:20
It may need to use the 32-bit powershell.
Edit your C:\Program Files (x86)\Nagios\NCPA\etc\ncpa.cfg on the Windows server and comment out this one that is uncommented:
To this:
Then add this one in its place:
Then restart the ncpa_listener service on the Windows system, run the check again, and let us know the results.
EDIT: If that doesn't fix it, you may need to do this:
https://www.michev.info/Blog/Post/1355/ ... et-missing
If that doesn't fix it, try reverting the ncpa.cfg back to use the original .ps1 line and then test again.
.ps1 = powershell -ExecutionPolicy Bypass -File $plugin_name $plugin_argsCode: Select all
#.ps1 = powershell -ExecutionPolicy Bypass -File $plugin_name $plugin_argsCode: Select all
.ps1 = c:\windows\sysnative\windowspowershell\v1.0\powershell.exe -ExecutionPolicy Bypass -File $plugin_name $plugin_argsEDIT: If that doesn't fix it, you may need to do this:
kalyanpabolu
Hello Sean,
We are able to get the output now, but the timestamp it is showing is incorrect. The latest sync timing is around 1 PM GT today.
But, in attached screenshot, you can see its showing 11:48 AM GST.
Is there nay difference in between heart beat event and sync?
Please suggest.
Please suggest.
The time output is coming directly from the plugin, I would check the date/time on the remote system that is running the plugin, I don't think NCPA would have any impact on it, do this:
- Login to the Windows system:
- Open up a 32bit powershell session as an admin
- cd into C:\Program Files (x86)\Nagios\NCPA\plugins
- Run the plugin manually, what does it output?
