Lenovo XClarity Integrator for Nagios
s7530995
Post by s7530995 »
I have a problem about use nagios XI to check my Lenovo XClarity.
I had already follow the steps to finish ,but it shows error.
https://sysmgt.lenovofiles.com/help/ind ... setup.html
I had no idea how to fix it.
I use this plugin from lenovo.
the error result showed as attachment.
benjaminsmith
Re: Lenovo XClarity Integrator for Nagios
Post by benjaminsmith »
RIght now Nagios XI installs python 2, did you install python 3 on the XI server. You'll likely need to change the command to call the plugin and the correct version of python.
Next, it's trying to access the file below but the nagios user account does not have sufficient permissions.
/home/nagios/logs/testpass.db
Change to:
chmod 775 /home/nagios/logs/testpass.db
If the problem persists, please attach the plugin to the ticket and I will test it out on my system.
Regards,
Benjamin
