Object API for ServiceStatus / StateHistory not working
rajasegar
Post by rajasegar »
Nagios 5.7.5
Red Hat 7.4
I have a strange problem.
Object API working for other command except ServiceStatus, StateHistory on the same server.
It just drops to command line after about 3 seconds.
The command picked straight from Object API help.
API is from an admin user
This works for all other 6 instances, off course with different IP and API key.
[nagios@nagiosprodxi1 scripts]$/usr/bin/curl -v -XGET 'http://10.17.19.234/nagiosxi/api/v1/objects/statehistory&search=&reportperiod=last24hours&startdate=&enddate=&hostgroup=&servicegroup=&statetype=both&?apikey=n3UYgnsqnfJX84rBNqRG3qbbi2WpjFaZX4XdqJW8fG5mZPd4v4JRua26bXPtSfs6&outputtype=xml'
* About to connect() to 10.17.19.234 port 80 (#0)
*   Trying 10.17.19.234... connected
* Connected to 10.17.19.234 (10.17.19.234) port 80 (#0)
> GET /nagiosxi/api/v1/objects/statehistory&search=&reportperiod=last24hours&startdate=&enddate=&hostgroup=&servicegroup=&statetype=both&?apikey=n3UYgnsqnfJX84rBNqRG3qbbi2WpjFaZX4XdqJW8fG5mZPd4v4JRua26bXPtSfs6&outputtype=xml HTTP/1.1
> User-Agent: curl/7.19.7 (x86_64-redhat-linux-gnu) libcurl/7.19.7 NSS/3.14.3.0 zlib/1.2.3 libidn/1.18 libssh2/1.4.2
> Host: 10.17.19.234
> Accept: */*
* HTTP 1.0, assume close after body
< HTTP/1.0 500 Internal Server Error
< Date: Tue, 04 May 2021 08:45:59 GMT
< Server: Apache/2.2.15 (Red Hat)
< X-Powered-By: PHP/5.3.3
< Access-Control-Allow-Origin: *
< Access-Control-Allow-Methods: POST, GET, OPTIONS, DELETE, PUT
< Content-Length: 0
< Connection: close
< Content-Type: application/xml
* Closing connection #0
[nagios@nagiosprodxi3 ~]$ curl -v -XGET "http://10.17.19.234/nagiosxi/api/v1/objects/statehistory?apikey=n3UYgnsqnfJX84rBNqRG3qbbi2WpjFaZX4XdqJW8fG5mZPd4v4JRua26bXPtSfs6&pretty=1"
> GET /nagiosxi/api/v1/objects/statehistory?apikey=n3UYgnsqnfJX84rBNqRG3qbbi2WpjFaZX4XdqJW8fG5mZPd4v4JRua26bXPtSfs6&pretty=1 HTTP/1.1
> User-Agent: curl/7.19.7 (x86_64-redhat-linux-gnu) libcurl/7.19.7 NSS/3.16.2.3 Basic ECC zlib/1.2.3 libidn/1.18 libssh2/1.4.2
> Host: 10.17.19.234
> Accept: */*
< Date: Tue, 04 May 2021 08:39:12 GMT
< Content-Length: 0
< Connection: close
< Content-Type: application/json
Please advice how to troubleshoot this.
5 x Nagios 5.6.9 Enterprise Edition
RHEL 6 & 7
rrdcached & ramdisk optimisation
vtrac
Re: Object API for ServiceStatus / StateHistory not working
Post by vtrac »
Hope you are having a good day!! ... :-)
I noticed the error:
Can you please check the "/var/log/httpd/error_log"?
Can you please try upgrade "curl"?
yum update curl
Also, please try restart httpd:
systemctl restart httpd
Now, can you please try just "servicestatus" and update outputs to this forum:
/usr/bin/curl -v -XGET "http://10.17.19.234/nagiosxi/api/v1/objects/servicestatus?apikey=n3UYgnsqnfJX84rBNqRG3qbbi2WpjFaZX4XdqJW8fG5mZPd4v4JRua26bXPtSfs6&pretty=1"
"hoststatus":
/usr/bin/curl -v -XGET "http://10.17.19.234/nagiosxi/api/v1/objects/hoststatus?apikey=n3UYgnsqnfJX84rBNqRG3qbbi2WpjFaZX4XdqJW8fG5mZPd4v4JRua26bXPtSfs6&pretty=1"
Best Regards,
Vinh
rajasegar
Post by rajasegar »
curl updated
httpd restarted
All nagios services restarted
Database repair script executed successfully.
No errors at all when executing the failed API in httpd/error_log
Servicestatus does not work
[nagios@nagiosprodxi3 scripts]$ /usr/bin/curl -v -XGET "http://10.17.19.234/nagiosxi/api/v1/objects/servicestatus?apikey=n3UYgnsqnfJX84rBNqRG3qbbi2WpjFaZX4XdqJW8fG5mZPd4v4JRua26bXPtSfs6&pretty=1"
> GET /nagiosxi/api/v1/objects/servicestatus?apikey=n3UYgnsqnfJX84rBNqRG3qbbi2WpjFaZX4XdqJW8fG5mZPd4v4JRua26bXPtSfs6&pretty=1 HTTP/1.1
> User-Agent: curl/7.19.7 (x86_64-redhat-linux-gnu) libcurl/7.19.7 NSS/3.44 zlib/1.2.3 libidn/1.18 libssh2/1.4.2
> Host: 10.17.19.234
> Accept: */*
< Date: Wed, 05 May 2021 01:27:18 GMT
< Content-Length: 0
< Connection: close
Hoststatus works fine
[nagios@nagiosprodxi3 scripts]$ /usr/bin/curl -v -XGET "http://10.17.19.234/nagiosxi/api/v1/objects/hoststatus?apikey=n3UYgnsqnfJX84rBNqRG3qbbi2WpjFaZX4XdqJW8fG5mZPd4v4JRua26bXPtSfs6&pretty=1" > t.txt
> GET /nagiosxi/api/v1/objects/hoststatus?apikey=n3UYgnsqnfJX84rBNqRG3qbbi2WpjFaZX4XdqJW8fG5mZPd4v4JRua26bXPtSfs6&pretty=1 HTTP/1.1
> Host: 10.17.19.234
> Accept: */*
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:--  0:00:01 --:--:--     0< HTTP/1.1 200 OK
< Date: Wed, 05 May 2021 01:28:17 GMT
< Connection: close
< Transfer-Encoding: chunked
{ [data not shown]
100 6706k    0 6706k    0     0  4955k      0 --:--:--  0:00:01 --:--:-- 4960k* Closing connection #0
RHEL 6 & 7
vtrac
Post by vtrac »
How are you doing?
How many "hosts" do you have on this XI instance?
How many "services" do you have on this XI instance?
Could you try checking "object/service" instead? .... does this works?
(NOTE: This is a ONE line command):
/usr/bin/curl -v -k "http://10.17.19.234/nagiosxi/api/v1/objects/service?apikey=n3UYgnsqnfJX84rBNqRG3qbbi2WpjFaZX4XdqJW8fG5mZPd4v4JRua26bXPtSfs6&pretty=1"
Let try capture error when running the "curl" command:
1). Open a command prompt on your XI machine, then run the below command.
Let its running while you do step 2 (below).
tail -f /var/log/httpd/error_log
2). Now run the "object/servicestatus" again:
(NOTE: this is a ONE line command)
curl -v -k "http://192.168.23.61/nagiosxi/api/v1/ob ... h&pretty=1"
Do you get anything in the "/var/log/httpd/error_log"? .... please upload screenshot, if possible.
Can you please run this on your XI command prompt (please upload outputs):
Lastly, please upload "profile.zip":
Admin > System Config > System Profile > "Download Profile"
Best Regards,
Vinh
vtrac
Post by vtrac »
Also, please run and upload outputs of this command:
echo "SELECT table_name AS 'Table', round(((data_length + index_length) / 1024 / 1024), 2) 'Size in MB' FROM information_schema.TABLES WHERE table_schema IN ('nagios', 'nagiosql', 'nagiosxi');" | mysql -h 127.0.0.1 -uroot -pnagiosxi --table
Regards,
Vinh
rajasegar
Post by rajasegar »
vtrac wrote:Also, please run and upload outputs of this command:
Regards,
Vinh
As requested
[nagios@nagiosprodxi3 ~]$ echo "SELECT table_name AS 'Table', round(((data_length + index_length) / 1024 / 1024), 2) 'Size in MB' FROM information_schema.TABLES WHERE table_schema IN ('nagios', 'nagiosql', 'nagiosxi');" | mysql -h 127.0.0.1 -uroot -pnagiosxi --table
| Table                                      | Size in MB |
| nagios_acknowledgements                    |       0.00 |
| nagios_commands                            |       0.03 |
| nagios_commenthistory                      |     311.65 |
| nagios_comments                            |       0.17 |
| nagios_configfiles                         |       0.01 |
| nagios_configfilevariables                 |       0.01 |
| nagios_conninfo                            |       0.11 |
| nagios_contact_addresses                   |       0.01 |
| nagios_contact_notificationcommands        |       0.03 |
| nagios_contactgroup_members                |       0.01 |
| nagios_contactgroups                       |       0.00 |
| nagios_contactnotificationmethods          |      41.41 |
| nagios_contactnotifications                |      43.78 |
| nagios_contacts                            |       0.03 |
| nagios_contactstatus                       |       0.02 |
| nagios_customvariables                     |      23.41 |
| nagios_customvariablestatus                |      24.27 |
| nagios_dbversion                           |       0.00 |
| nagios_downtimehistory                     |      17.54 |
| nagios_eventhandlers                       |       1.03 |
| nagios_externalcommands                    |       0.00 |
| nagios_flappinghistory                     |     129.77 |
| nagios_host_contactgroups                  |       0.33 |
| nagios_host_contacts                       |       0.11 |
| nagios_host_parenthosts                    |       0.00 |
| nagios_hostchecks                          |       1.21 |
| nagios_hostdependencies                    |       0.00 |
| nagios_hostescalation_contactgroups        |       0.00 |
| nagios_hostescalation_contacts             |       0.00 |
| nagios_hostescalations                     |       0.00 |
| nagios_hostgroup_members                   |       0.22 |
| nagios_hostgroups                          |       0.00 |
| nagios_hosts                               |       0.52 |
| nagios_hoststatus                          |       1.43 |
| nagios_instances                           |       0.00 |
| nagios_logentries                          |    3440.58 |
| nagios_notifications                       |     114.47 |
| nagios_objects                             |       4.93 |
| nagios_processevents                       |       0.02 |
| nagios_programstatus                       |       0.00 |
| nagios_runtimevariables                    |       0.00 |
| nagios_scheduleddowntime                   |       0.00 |
| nagios_service_contactgroups               |       2.00 |
| nagios_service_contacts                    |       0.65 |
| nagios_service_parentservices              |       0.00 |
| nagios_servicechecks                       |       4.09 |
| nagios_servicedependencies                 |       0.00 |
| nagios_serviceescalation_contactgroups     |       0.00 |
| nagios_serviceescalation_contacts          |       0.00 |
| nagios_serviceescalations                  |       0.00 |
| nagios_servicegroup_members                |       0.00 |
| nagios_servicegroups                       |       0.00 |
| nagios_services                            |       3.67 |
| nagios_servicestatus                       |      10.46 |
| nagios_statehistory                        |    2796.52 |
| nagios_systemcommands                      |       0.02 |
| nagios_timedeventqueue                     |       0.00 |
| nagios_timedevents                         |       0.00 |
| nagios_timeperiod_timeranges               |       0.01 |
| nagios_timeperiods                         |       0.00 |
| PAAS_LIST                                  |       0.13 |
| tbl_command                                |       0.05 |
| tbl_contact                                |       0.04 |
| tbl_contactgroup                           |       0.01 |
| tbl_contacttemplate                        |       0.01 |
| tbl_domain                                 |       0.01 |
| tbl_host                                   |       0.31 |
| tbl_hostdependency                         |       0.00 |
| tbl_hostescalation                         |       0.00 |
| tbl_hostextinfo                            |       0.00 |
| tbl_hostgroup                              |       0.01 |
| tbl_hosttemplate                           |       0.02 |
| tbl_info                                   |       0.13 |
| tbl_lnkContactToCommandHost                |       0.00 |
| tbl_lnkContactToCommandService             |       0.00 |
| tbl_lnkContactToContactgroup               |       0.00 |
| tbl_lnkContactToContacttemplate            |       0.01 |
| tbl_lnkContactToVariabledefinition         |       0.00 |
| tbl_lnkContactgroupToContact               |       0.01 |
| tbl_lnkContactgroupToContactgroup          |       0.00 |
| tbl_lnkContacttemplateToCommandHost        |       0.00 |
| tbl_lnkContacttemplateToCommandService     |       0.00 |
| tbl_lnkContacttemplateToContactgroup       |       0.00 |
| tbl_lnkContacttemplateToContacttemplate    |       0.00 |
| tbl_lnkContacttemplateToVariabledefinition |       0.00 |
| tbl_lnkHostToContact                       |       0.00 |
| tbl_lnkHostToContactgroup                  |       0.00 |
| tbl_lnkHostToHost                          |       0.00 |
| tbl_lnkHostToHostgroup                     |       0.00 |
| tbl_lnkHostToHosttemplate                  |       0.08 |
| tbl_lnkHostToVariabledefinition            |       0.00 |
| tbl_lnkHostdependencyToHost_DH             |       0.00 |
| tbl_lnkHostdependencyToHost_H              |       0.00 |
| tbl_lnkHostdependencyToHostgroup_DH        |       0.00 |
| tbl_lnkHostdependencyToHostgroup_H         |       0.00 |
| tbl_lnkHostescalationToContact             |       0.00 |
| tbl_lnkHostescalationToContactgroup        |       0.00 |
| tbl_lnkHostescalationToHost                |       0.00 |
| tbl_lnkHostescalationToHostgroup           |       0.00 |
| tbl_lnkHostgroupToHost                     |       0.06 |
| tbl_lnkHostgroupToHostgroup                |       0.00 |
| tbl_lnkHosttemplateToContact               |       0.00 |
| tbl_lnkHosttemplateToContactgroup          |       0.00 |
| tbl_lnkHosttemplateToHost                  |       0.00 |
| tbl_lnkHosttemplateToHostgroup             |       0.00 |
| tbl_lnkHosttemplateToHosttemplate          |       0.00 |
| tbl_lnkHosttemplateToVariabledefinition    |       0.00 |
| tbl_lnkServiceToContact                    |       0.00 |
| tbl_lnkServiceToContactgroup               |       0.00 |
| tbl_lnkServiceToHost                       |       0.00 |
| tbl_lnkServiceToHostgroup                  |       0.00 |
| tbl_lnkServiceToServicegroup               |       0.00 |
| tbl_lnkServiceToServicetemplate            |       0.00 |
| tbl_lnkServiceToVariabledefinition         |       0.00 |
| tbl_lnkServicedependencyToHost_DH          |       0.00 |
| tbl_lnkServicedependencyToHost_H           |       0.00 |
| tbl_lnkServicedependencyToHostgroup_DH     |       0.00 |
| tbl_lnkServicedependencyToHostgroup_H      |       0.00 |
| tbl_lnkServicedependencyToService_DS       |       0.00 |
| tbl_lnkServicedependencyToService_S        |       0.00 |
| tbl_lnkServicedependencyToServicegroup_DS  |       0.02 |
| tbl_lnkServicedependencyToServicegroup_S   |       0.02 |
| tbl_lnkServiceescalationToContact          |       0.00 |
| tbl_lnkServiceescalationToContactgroup     |       0.00 |
| tbl_lnkServiceescalationToHost             |       0.00 |
| tbl_lnkServiceescalationToHostgroup        |       0.00 |
| tbl_lnkServiceescalationToService          |       0.00 |
| tbl_lnkServiceescalationToServicegroup     |       0.02 |
| tbl_lnkServicegroupToService               |       0.00 |
| tbl_lnkServicegroupToServicegroup          |       0.00 |
| tbl_lnkServicetemplateToContact            |       0.00 |
| tbl_lnkServicetemplateToContactgroup       |       0.00 |
| tbl_lnkServicetemplateToHost               |       0.00 |
| tbl_lnkServicetemplateToHostgroup          |       0.00 |
| tbl_lnkServicetemplateToServicegroup       |       0.00 |
| tbl_lnkServicetemplateToServicetemplate    |       0.01 |
| tbl_lnkServicetemplateToVariabledefinition |       0.00 |
| tbl_lnkTimeperiodToTimeperiod              |       0.00 |
| tbl_logbook                                |       0.00 |
| tbl_mainmenu                               |       0.00 |
| tbl_permission                             |       0.02 |
| tbl_permission_inactive                    |       0.02 |
| tbl_service                                |       0.00 |
| tbl_servicedependency                      |       0.00 |
| tbl_serviceescalation                      |       0.00 |
| tbl_serviceextinfo                         |       0.00 |
| tbl_servicegroup                           |       0.01 |
| tbl_servicetemplate                        |       0.02 |
| tbl_session                                |       0.00 |
| tbl_session_locks                          |       0.00 |
| tbl_settings                               |       0.00 |
| tbl_submenu                                |       0.00 |
| tbl_timedefinition                         |       0.01 |
| tbl_timeperiod                             |       0.01 |
| tbl_user                                   |       0.01 |
| tbl_variabledefinition                     |       0.01 |
| xi_auditlog                                |       0.06 |
| xi_auth_tokens                             |       0.03 |
| xi_cmp_ccm_backups                         |       0.02 |
| xi_cmp_favorites                           |       0.03 |
| xi_cmp_nagiosbpi_backups                   |       0.08 |
| xi_cmp_trapdata                            |       0.03 |
| xi_cmp_trapdata_log                        |       0.03 |
| xi_commands                                |       0.00 |
| xi_deploy_agents                           |       0.02 |
| xi_deploy_jobs                             |       0.02 |
| xi_eventqueue                              |       0.36 |
| xi_events                                  |       5.91 |
| xi_incidents                               |       0.00 |
| xi_meta                                    |     111.02 |
| xi_mibs                                    |       0.05 |
| xi_options                                 |       0.76 |
| xi_sessions                                |       0.03 |
| xi_sysstat                                 |       0.01 |
| xi_usermeta                                |       0.28 |
| xi_users                                   |       0.01 |
RHEL 6 & 7
rajasegar
Post by rajasegar »
vtrac wrote:Hi,
How are you doing?
Best Regards,
Vinh
Total Hosts - 2217
Total Services - 16230
"object/service" works fine
[nagios@nagiosprodxi3 ~]$ /usr/bin/curl -v -k "http://10.17.19.234/nagiosxi/api/v1/objects/service?apikey=n3UYgnsqnfJX84rBNqRG3qbbi2WpjFaZX4XdqJW8fG5mZPd4v4JRua26bXPtSfs6&pretty=1" > t.txt
> GET /nagiosxi/api/v1/objects/service?apikey=n3UYgnsqnfJX84rBNqRG3qbbi2WpjFaZX4XdqJW8fG5mZPd4v4JRua26bXPtSfs6&pretty=1 HTTP/1.1
> Host: 10.17.19.234
> Accept: */*
  0     0    0     0    0     0      0      0 --:--:--  0:00:03 --:--:--     0< HTTP/1.1 200 OK
< Date: Thu, 06 May 2021 02:44:10 GMT
< Connection: close
{ [data not shown]
100 13.3M    0 13.3M    0     0  4477k      0 --:--:--  0:00:03 --:--:-- 4478k* Closing connection #0
As updated earlier there is nothing coming out on httpd/error_log.
[nagios@nagiosprodxi3 ~]$ /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg
Nagios Core 4.4.6
Last Modified: 2020-04-28
License: GPL
Reading configuration data...
   Read main config file okay...
Checking objects...
        Checked 16230 services.
        Checked 2705 hosts.
        Checked 17 host groups.
        Checked 1 service groups.
        Checked 196 contacts.
        Checked 59 contact groups.
        Checked 211 commands.
        Checked 18 time periods.
        Checked 0 host escalations.
        Checked 2705 hosts
        Checked 0 host dependencies
        Checked 18 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors:   0
I will PM you the profile
RHEL 6 & 7
vtrac
Post by vtrac »
Hope you are doing good!! ... :-)
We now know that your system is very large with "16,230" services.
We also know that the API did work for "object/service" but not "object/servicestatus".
I talked to my senior team member here and they said to increase the memory and other values to "5x" in the "/etc/php.ini" file.
So, could you please try the followings, under the "Resource Limits" section, please increase those values to at least "5x".
; Resource Limits ;
; Maximum execution time of each script, in seconds
; http://php.net/max-execution-time
; Note: This directive is hardcoded to 0 for the CLI SAPI
max_execution_time = 300
; Maximum amount of time each script may spend parsing request data. It's a good
; idea to limit this time on productions servers in order to eliminate unexpectedly
; long running scripts.
; Note: This directive is hardcoded to -1 for the CLI SAPI
; Default Value: -1 (Unlimited)
; Development Value: 60 (60 seconds)
; Production Value: 60 (60 seconds)
; http://php.net/max-input-time
max_input_time = 600
; Maximum input variable nesting level
; http://php.net/max-input-nesting-level
;max_input_nesting_level = 64
; How many GET/POST/COOKIE input variables may be accepted
max_input_vars = 25000
; Maximum amount of memory a script may consume (128MB)
; http://php.net/memory-limit
memory_limit = 1280M
We must now restart HTTP:
Now, please try the command again. Let try capture error when running the "curl" command:
2). Now run the "object/servicestatus" again. Open a second command prompt on the XI machine:
Please up outputs (results) and screenshot, if possible.
Best Regards,
Vinh
rajasegar
Post by rajasegar »
vtrac wrote:Hi,
; Resource Limits ;
Best Regards,
Vinh
Thanks. It works fine now. You can close the thread.
RHEL 6 & 7
rajasegar wrote:
vtrac wrote:Hi,
; Resource Limits ;
Best Regards,
Vinh
Locking thread
