Issues logging in to logserver console
We are currently having some difficulties with being able to access the Log server through the console. We have done several resets from the command line with no success. We are trying to figure out if there is a way to reset Nagios admin credential and if you are able to point us to the right direction.
Re: Issues logging in to logserver console
Just do a:
it will then prompt you for a new password:
Let me know how that works for you.
Just do a:
/usr/local/nagioslogserver/scripts/reset_nagiosadmin_password.shCode: Select all
Enter a new password:Thanks
