I am a bit confused because nagios does not send a notification.
I wrote a perl script which does send a sms at the end. In the command definition I tell my script the $CONTACTPAGER$ and all other stuff like status, message, time etc.
I see the following in the logs from nagios.
[1622106617] EXTERNAL COMMAND: SCHEDULE_FORCED_SVC_CHECK;HOSTNAME;sms notification test;1622106617
[1622106617] SERVICE ALERT: HOSTNAME;sms notification test;CRITICAL;SOFT;1;CRITICAL, no process matching Service.exe
[1622106622] EXTERNAL COMMAND: SCHEDULE_FORCED_SVC_CHECK;HOSTNAME;sms notification test;1622106622
[1622106623] SERVICE ALERT: HOSTNAME;sms notification test;CRITICAL;SOFT;2;CRITICAL, no process matching Service.exe
[1622106626] EXTERNAL COMMAND: SCHEDULE_FORCED_SVC_CHECK;HOSTNAME;sms notification test;1622106626
[1622106627] SERVICE NOTIFICATION: contact-user-sms;HOSTNAME;sms notification test;CRITICAL;notify-service-by-sms;CRITICAL, no process matching Service.exe
[1622106627] SERVICE ALERT: HOSTNAME;sms notification test;CRITICAL;HARD;3;CRITICAL, no process matching Service.exe
Therefore the check goes
- Soft 1
- Soft 2
- Hard 3 and then triggers the SERVICE NOTIFICATION for the user I want and with the command I configured but nothing happens
At thruk I see notification 1 but when I click on "View notifications for this service" its empty.
I tried also to switch to user nagios and execute the script from the command line and this works.
At the moment I dont get where the problem is. Are there any hints guys?
Thank you in advance
Notification not sent but nagios triggers command
thomaszwei
