Hi, I've just begun my 30 day trial. I have a host that is drive swapping at just barely over the critical limit. How can I change the critical limit for just that one server? How can I change it for all servers?
Nice product so far! Tons of options!
Change warning and critical alert thresholds
Re: Change warning and critical alert thresholds
Select Configure, Core Config Manager Select the blue Services box Edit the service you are interested in by clicking on the wrench
in the Actions column.
Make the changes and hit the Save button.
Finally hit the Apply Configuration button.
Let me know if you were successful or not please.
Thanks!
Thanks!
That did work, thank you. I was only seeing "localhost" and not any other entries. I had to navigate to the next page to see the host I was looking for.
