Windows Activation Monitoring
kalyanpabolu
Hi Team,
Can we monitor Windows Activation using Nagios XI?
We recently faced issue where Windows was not activated on a machine and that created a big problem.
Is there a way in Nagios where we can get alert for Windows systems if in case Windows is not activated for them.
Please suggest.
Thanks in advance!!
Please suggest.
Thanks in advance!!
Re: Windows Activation Monitoring
How are you doing?
I would suggest that you write your own plugin, then calls it using "check_ncpa.py".
Here's an example. Please NOTE I'm not a PowerShell programmer, so you will have to modify or add more to the example below:
Outputs:
If your output of "LicenseStatus" is "1" as above, then your system is activated.
Best Regards,
Vinh
How are you doing?
(Get-CimInstance SoftwareLicensingProduct -Filter "Name like 'Windows%'" | where { $_.PartialProductKey } | select Description, LicenseStatus)
Description LicenseStatus
Windows(R) Operating System, OEM_DM channel 1
Best Regards,
Vinh
Also, please NOTE that the provided PS example command seems to take a few seconds to run, so you might have to set bigger for "timeout".
Vinh
Vinh
kalyanpabolu
thanks for your inputs.
We are not willing to place any script on windows machine.
Is that possible to check it using a shell script or say plugin from Nagios server?
Hi @kalyanpabolu,
Hope you are having a good day!!
I'm very sorry, but Nagios do not have any module that will check for Windows license activation.
I was suggested as a way to get that in my previous replied but you must come up with your own PowerShell script.
Best Regards,
Vinh
Best Regards,
Vinh
kalyanpabolu
We have run the command "slmgr.vbs -xpr" in one of the servers and we got the pop-up(PFA) in which its is showing volume activation expiration date. Please let us know how we can monitor this pop-up result through Nagios.
This should be the same process:
https://support.nagios.com/forum/viewto ... 671#p39671
What does this output?
cscript //NoLogo c:\windows\system32\slmgr.vbs -xpr | find "expire"-
kalyanpabolu
Thank you for your reply!!
Please find attached output of the command you gave. Actually we don't have NSClient++ installed on our machines. Can we monitor this with NCPA?
Yes, you can us NCPA.
Create a bat file let call it "check_license.bat" and put that under NCPA's plugins folder:
"C:\Program Files (x86)\Nagios\NCPA\plugins\"
Now, open a command prompt from your Nagios XI and run:
Regards,
Vinh
/usr/local/nagios/libexec/check_ncpa.py -H x.x.x.x -t 'yourNCPAtoken' -M 'plugins/check_license.bat'
Regards,
Vinh
kalyanpabolu
Thank you!!! it is working. We have tested it one of the our machine and it is working fine(PFA).
Can you please help me to monitor this activation date, show it Critical and Warning in Nagios and send an alert when license is about to expire in 30 and 60 days respectively ?
Thanks in advance.
Thanks in advance.
