Nagios Service is going down
kn00567386
Post by kn00567386 »
Hello Team,
We are observing that Nagios service is going down frequently on server. below are the logs observe in messages. I Have tried to repair database and run reconfigure_nagios script, but no success. Service is getting start but goes down after few minutes.
Jun 14 10:54:34 wdc-nagios01d nagios[9878]: Caught SIGSEGV, shutting down...
Jun 14 10:54:34 wdc-nagios01 systemd[1]: nagios.service: main process exited, code=exited, status=254/n/a
Jun 14 10:54:34 wdc-nagios01 nagios[9979]: Caught SIGTERM, shutting down...
Jun 14 10:54:34 wdc-nagios01 systemd[1]: Unit nagios.service entered failed state.
Jun 14 10:54:34 wdc-nagios01 systemd[1]: nagios.service failed.
kn00567386
Re: Nagios Service is going down
Another observation from logs:
[1623671042] NDO-3: mysql_ping: Unknown error. Is the database running?
[1623671042] Caught SIGSEGV, shutting down...
[1623671042] Caught SIGTERM, shutting down...
vtrac
Post by vtrac »
How are you doing?
May I ask if there is/are changes make to the OS and/or Nagios Xi system?
To further investigate the issue, could you please upload the system "profile.zip":
Click the "Admin" > "System Config" > "System Profile" Menu
If you're unable to generate the the profile through the web interface,
please try generating it from the command line by running these commands as root:
rm -rf /usr/local/nagiosxi/var/components/profile*​​
/usr/local/nagiosxi/scripts/components/getprofile.sh SUPPORT
Please also post the full output of the following command to check the table sizes.
- NOTE: You may need to adjust the -h 127.0.0.1, the -uroot, and -pnagiosxi in the first command if your DB is offloaded to another server and/or you've changed the root mysql password
echo "SELECT table_name AS 'Table', round(((data_length + index_length) / 1024 / 1024), 2) 'Size in MB' FROM information_schema.TABLES WHERE table_schema IN ('nagios', 'nagiosql', 'nagiosxi');" | mysql -h 127.0.0.1 -uroot -pnagiosxi --table
Best Regards,
Vinh
