I am a bit confused by the notification timing.
I've read in documentation articles that Service Check Intervals need to be equal to or greater than the Notification Intervals.
I have a service with a Check interval of 7 minutes and a notification interval of 7 minutes. When I set the condition to trigger the alert, Nagios sends alerts every 21 or 22 minutes.
Is there another location that I need to be looking at?
Notification Timing
Re: Notification Timing
How are you doing?
Here's an example of notification settings: Based on the picture "F1", the "Check Interval" is every "5" minutes.
Once issue is identified, Nagios XI will check every "1" minute (Retry interval) for up to "5" times (Max check attempts) before sending out notification.
So, based on the above settings, notification will be sent out after "5" check attempts of every "1" minute = "5" minutes.
We have some customers that want to sent out notification after "15" minutes once issue has been identified, so they would set:
Check interval = 5
Retry interval = 3
Max check attemps = 5
Notification Interval: As to "Notification Interval", it is used to define the number of "time units" (usually 60 minutes) to wait before re-notifying again that this service is still in a non-OK state.
Hope this helps!!
Best Regards,
Vinh
How are you doing?
Check interval = 5
Retry interval = 3
Hope this helps!!
Best Regards,
Vinh
