NCPA Issue
mindspring
NCPA Issue
Post by mindspring »
Hi There,
I started getting this error message in monitoring an Artisan process using NCPA
UNKNOWN: The node (process) requested does not exist. You may be trying to access the 'processes' node.
In the log file I can see the check running
2021-07-05 09:00:29,478 8693 INFO ::ffff:<IPADDRESS> - - [2021-07-05 09:00:29] "GET /api/processes/?token=<PASSWPRD>&warning=40%3A&critical=20%3A&check=1&cmd=artisan&match=search HTTP/1.1" 200 3519 0.775105
Here is the configuration check from NagiosXI service configure:
check_xi_ncpa!-t 'password' -P 5693 -M 'process/artisan/count' -w -50 -c -10!!!!!!!
Any ideas on this?
dchurch
Re: NCPA Issue
Post by dchurch »
Hi!
Can you please try changing the check to:
check_xi_ncpa!-t 'password' -P 5693 -M 'processes/artisan/count' -w -50 -c -10!!!!!!!
mindspring
Re: NCPA Issue
Ah thanks, i copied this from another service check and this seems to have worked:
check_xi_ncpa!-t 'password' -M 'processes' -w 4: -c 3: -q 'cmd=artisan,match=search' !!!!!!!
I wanted to tweak this alert a bit more by adding different checks for different artisan process types.
root       603  0.0  0.0 113284  1380 pts/0    Ss+  Jul05   0:00 bash -c cd /var/www/html/api/;  while true; do php artisan queue:listen ; sleep 1 ; done; exec sh
root      9309  5.0  0.1 416284 36004 pts/0    S+   03:35   0:00 /usr/bin/php artisan queue:work --once --name=default --queue=default --backoff=0 --memory=128 --sleep=3 --tries=1
nginx     9316 11.0  0.1 416284 36012 ?        S    03:36   0:00 /usr/bin/php artisan queue:work --once --name=default --queue=default --backoff=0 --memory=128 --sleep=3 --tries=3
nginx     9317 11.0  0.1 416284 36016 ?        S    03:36   0:00 /usr/bin/php artisan queue:work --once --name=default --queue=default --backoff=0 --memory=128 --sleep=3 --tries=3
root      9362  0.0  0.0 112816   972 pts/1    S+   03:36   0:00 grep --color=auto artisan
nginx    22394  0.0  0.1 416280 35928 ?        S    Jul05   1:54 php /var/www/html/api/[b]artisan queue:listen[/b] --sleep=3 --tries=3
root     22409  0.0  0.1 416280 35924 pts/0    S+   Jul05   1:53 php artisan queue:listen
nginx    22410  0.0  0.1 416280 35928 ?        S    Jul05   1:52 php /var/www/html/api/artisan queue:listen --sleep=3 --tries=3
For example, this has the different types in bold above, artisan queue:listen and artisan queue:work
Could I do something like the below?
check_xi_ncpa!-t 'password' -M 'processes' -w 4: -c 3: -q 'cmd=artisan queue:listen,match=search' !!!!!!!
check_xi_ncpa!-t 'password' -M 'processes' -w 4: -c 3: -q 'cmd=artisan queue:work,match=search' !!!!!!!
UPDATE:
I tried the above method but I can't tell if it's working properly or not. The output of on NagiosXI looks like below:
Processes Matched
PID: Name: Username: Exe: Memory: CPU
695: php: root: 0.11 % (VMS 0.45 GB, RSS 0.03 GB): 0.00 %
1050: php: root: 0.12 % (VMS 0.45 GB, RSS 0.03 GB): 0.00 %
2935: php: root: 0.11 % (VMS 0.45 GB, RSS 0.03 GB): 0.00 %
4096: php: root: 0.11 % (VMS 0.45 GB, RSS 0.03 GB): 0.00 %
4383: php: root: 0.11 % (VMS 0.45 GB, RSS 0.03 GB): 0.00 %
4756: php: root: 0.11 % (VMS 0.45 GB, RSS 0.03 GB): 0.00 %
5604: php: root: 0.11 % (VMS 0.45 GB, RSS 0.03 GB): 0.00 %
5862: php: root: 0.11 % (VMS 0.45 GB, RSS 0.03 GB): 0.00 %
7006: php: root: 0.11 % (VMS 0.45 GB, RSS 0.03 GB): 0.00 %
7023: php: root: 0.11 % (VMS 0.45 GB, RSS 0.03 GB): 0.00 %
28587: php: root: 0.11 % (VMS 0.45 GB, RSS 0.03 GB): 0.00 %
42730: php: root: 0.11 % (VMS 0.45 GB, RSS 0.03 GB): 0.00 %
So it doesn't really show the full process. Any ideas?
dchurch
Re: NCPA Issue
Post by dchurch »
Your modification appears to be working when I labbed this up. Try shutting down the artisan queue workers and see if the check stays the same.
Here's how to execute it from the Nagios XI machine's command line:
/usr/local/nagios/libexec/check_ncpa.py -H <your NCPA host IP> -t 'password' -M 'processes' -w 4: -c 3: -q 'cmd=artisan queue:work,match=search'
mindspring
Re: NCPA Issue
Many thanks, yes this is working.
dchurch
Re: NCPA Issue
Post by dchurch »
Glad to hear you resolved it! Locking thread.
If you have any additional issues, feel free to make a new thread.
