Bulk host cloning and import not working
deek
Post by deek »
Hello Team ,
The configuration wizard Bulk Host cloning and import is not working all of a sudden . We see a blank white page when we click on the icon .
Could you help us on this . We are using Nagios 5.6.7 version .
Thanks ,
Deek
deek
Re: Bulk host cloning and import not working
Post by deek »
And also we have another issue .
When we click on create new BPI group under BPI we see a blank page . Please suggest what can be done here .
gsmith
Post by gsmith »
Hi
What OS are you running?
deek
Post by deek »
OS is linux
gsmith
Post by gsmith »
Please run the following commands and send me the output:
sudo cat /etc/os-release
sudo lsb_release -a
sudo hostnamectl
sudo uname -r
Thank you
deek
Post by deek »
We got it fixed . We modified some values in the php.ini file and it worked .
max_input_vars = 50000
memory_limit = 1024M
max_execution_time = 900
max_input_time = 900
