How to remove Forgot your password?
pavan509
Post by pavan509 »
Hello Team,
According to my client requirement, after integrating the Nagios with AD, users should not see the "Forgot your password?" on the login screen. As users should reach out to the AD team or service desk to reset the AD password. Is it possible to do that? If so, what will be the process to do.
Thanks, Pavan
gsmith
Re: How to remove Forgot your password?
Post by gsmith »
Hi
It is not possible to do this as the "Forgot your password?" link is in a
compiled file and the source for that file is not available to the end
user.
pavan509
Post by pavan509 »
Hello Smith,
Thanks for your response.
Thanks, Pavan
