Service Availability report not generating any data
Hello Team,
When I run the reports and download it, getting the required information without any issues. For the scheduled reports, getting the host level availability report without any issues, but seeing the error "Availability data is not available when monitoring engine is not running." in the service availability reports. Attached is the snippet of the error for reference.
Please advise on this issue.
Thanks, Pavan
Re: Service Availability report not generating any data
Hello @pavan509
Thanks for reaching out and providing the details. Appears that the nagios monitoring service is not running.
We want to run through this and please pay close attention to see if any errors *(for example, cfg issues) that could be causing issues. Run the following:
Then:
Please check to verify that the nagios service is running by:
If you see that the service is not running please send along the Nagios System Profile:
To send us your system profile.
Perry
service nagios stopCode: Select all
killall -9 nagios or pkill nagiosCode: Select all
service nagios startCode: Select all
/usr/local/nagiosxi/scripts/reconfigure_nagios.shCode: Select all
systemctl status nagiosTo send us your system profile.
- Login to the Nagios XI GUI using a web browser.
- Click the "Admin" > "System Profile" Menu
- Click the "Download Profile" button
- Save the profile.zip file and share
Perry
Hello Perry,
I have followed your instructions and restarted the Nagios service. Getting the reports as attachments via email but the reports seem to be blank. I have sent the system profile via PM to you. Kindly review it and advise on how to proceed further.
Thanks, Pavan
Hello @pavan509
Thanks for taking the time to send over the System Profile. As you know the Service Availability report is generated from Nagios logs report pulling from the date on the file name. We are wondering if logrotation is not working or possibly other reasons. Would like to get the following system information from this one-liner (copy/paste command)
Please send us the results.txt when you get a chance.
Perry
ls -alR /usr/local/nagios/var/ > results.txt && ls -al /usr/local/nagios/var/ >> results.txt && cat /usr/local/nagios/etc/nagios.cfg | grep log_archive_path >> results.txt && grep '' /etc/logrotate.d/* >> results.txt && cat /etc/logrotate.conf >> results.txt && /usr/local/nagios/bin/nagios -V >> results.txt && /usr/sbin/logrotate -v /etc/logrotate.d/nagiosxi >> results.txtThanks,
Perry
I think you are hitting a bug that was fixed in XI 5.8.5:
https://www.nagios.com/downloads/nagios-xi/change-log/
You can upgrade to XI 5.8.5 OR to fix your version you can edit this file:
Change this (around line 231):
To this:
Taken from here:5.8.5 - 07/15/2021
Fixed issue when generating PDFs (and auth tokens in general) on usernames with uppercase letters in them [TPS#15542] -JO
/usr/local/nagiosxi/html/includes/auth.inc.phpCode: Select all
$_SESSION["username"] = strtolower($username);Code: Select all
$_SESSION["username"] = $username;Re: Service Availability report not generating any data
Hello Perry,
Please find the logs result file as attached from the one-liner command which you have provided.
@ssax,
The solution provided for you worked for one-time scheduled reports but not working for the weekly/monthly scheduled reports.
@ssax,
Thanks, Pavan
Try creating a new scheduled report and see if that works.
Run this command as root and leave it running:
Then send one of the failing scheduled reports and send the full output of the still running tail command after it has failed.
tail -Fn0 /var/log/httpd/error_log /var/log/httpd/ssl_error_log /usr/local/nagiosxi/var/wkhtmltox.logRe: Service Availability report not generating any data
Hello @ssax,
I have scheduled a new report and let it run, no issues observed so far. However, when I try to run the old scheduled reports, getting the same error as mentioned at the starting of this thread. Below is the output of the command which you have provided when I ran the old scheduled report.
Kindly advise what went wrong and also let me know if I need to recreate all the scheduled reports.
--2021-09-06 07:39:21-- https://socavailmonitor2.schneider-electric.com/nagiosxi//reports/availability.php?reportperiod=lastweek&startdate=&enddate=&host=&service=&hostgroup=&servicegroup=&advanced=1&assumeinitialstates=yes&assumestateretention=yes&assumestatesduringdowntime=yes&includesoftstates=no&assumedhoststate=3&assumedservicestate=6&timeperiod=&locale=en_US&mode=csv&csvtype=host&token=058a6244f90c725b8ff14b6d652b81887e813735
Resolving socavailmonitor2.schneider-electric.com (socavailmonitor2.schneider-electric.com)... 10.236.177.248
Connecting to socavailmonitor2.schneider-electric.com (socavailmonitor2.schneider-electric.com)|10.236.177.248|:443... connected.
Length: unspecified [application/octet-stream]
Saving to: '/usr/local/nagiosxi/tmp/scheduledreport-ADM615438-MSVhAbuNSjoh-1630939161-Host_Availability.csv'
0K .......... . 915K=0.01s
2021-09-06 07:39:22 (915 KB/s) - '/usr/local/nagiosxi/tmp/scheduledreport-ADM615438-MSVhAbuNSjoh-1630939161-Host_Availability.csv' saved [12251]
--2021-09-06 07:39:22-- https://socavailmonitor2.schneider-electric.com/nagiosxi//reports/availability.php?reportperiod=lastweek&startdate=&enddate=&host=&service=&hostgroup=&servicegroup=&advanced=1&assumeinitialstates=yes&assumestateretention=yes&assumestatesduringdowntime=yes&includesoftstates=no&assumedhoststate=3&assumedservicestate=6&timeperiod=&locale=en_US&mode=csv&csvtype=service&token=39bb311938c574b9ab91391b09303fc1e2e3fd04
Saving to: '/usr/local/nagiosxi/tmp/scheduledreport-ADM615438-MSVhAbuNSjoh-1630939162-Service_Availability.csv'
0K .......... .......... .......... .......... .......... 22.8M
50K .......... .......... .......... .......... .......... 18.7M
100K .......... .......... .......... .......... .......... 19.1M
150K .......... .......... .......... .......... .......... 19.0M
200K .......... .......... .......... .......... .......... 16.7M
250K .......... .......... .......... .......... .......... 19.1M
300K .......... 261K=0.05s
2021-09-06 07:39:28 (5.53 MB/s) - '/usr/local/nagiosxi/tmp/scheduledreport-ADM615438-MSVhAbuNSjoh-1630939162-Service_Availability.csv' saved [317739]
Thanks, Pavan
Please PM me this file:
/var/spool/cron/apacheRe: Service Availability report not generating any data
Hello ssax,
I have shared the file with you via PM. Kindly review it and advise.
Thanks, Pavan
