NCPA disk checks output
Hello Nagios support
Please help to understand why Nagios xI output is different from NCPA API output:
Say, ./check_ncpa.py -H fikc-alfind02.konecranes.com -t '<your token>' -M 'disk/logical/|solr|suggestions' -w 80 -c 90
1. This is what API promises to show: CRITICAL: Used disk space was 100.00 % (Used: 376.47 GiB, Free: 0.00 GiB, Total: 393.48 GiB) | 'used'=376.47GiB;315;354; 'free'=0.00GiB;315;354; 'total'=393.48GiB;315;354;
2. That is what XI shows: CRITICAL: Used_percent was 100 % (this is it)
- Where are Total /Free?
Re: NCPA disk checks output
Hi
From the command line I get:
And here it is displayed ih the gui:
I even changed my mountpoint and got the same results:
So please provide the output of the following (using sudo if required):
Also send me a System Profile:
To send us your system profile.
1. Login to the Nagios XI GUI using a web browser.
2. Click the "Admin" > "System Profile" Menu
3. Click the "Download Profile" button
4. Save the profile.zip file and share this in a private message and then reply to this post to bring it up in the queue.
[root@gs-cent8-23-82 greg]# /usr/local/nagios/libexec/check_ncpa.py -H 192.168.23.82 -t 'gjstoken' -P 5693 -M 'disk/logical/|greg' -w '70' -c '90'
CRITICAL: Used disk space was 100.00 % (Used: 0.46 GiB, Free: 0.00 GiB, Total: 0.46 GiB) | 'used'=0.46GiB;;; 'free'=0.00GiB;;; 'total'=0.46GiB;;;
[root@gs-cent8-23-82 mysubdir]# mount -l
/dev/sdb on /greg/mysubdir type ext4 (rw,relatime)
cat /etc/os-release
uname -a
mount -l
cat /usr/local/nagiosxi/var/xiversion|grep full
Hellogsmith wrote:Hi
From the command line I get:And here it is displayed ih the gui: I even changed my mountpoint and got the same results:Code: Select all
[root@gs-cent8-23-82 greg]# /usr/local/nagios/libexec/check_ncpa.py -H 192.168.23.82 -t 'gjstoken' -P 5693 -M 'disk/logical/|greg' -w '70' -c '90' CRITICAL: Used disk space was 100.00 % (Used: 0.46 GiB, Free: 0.00 GiB, Total: 0.46 GiB) | 'used'=0.46GiB;;; 'free'=0.00GiB;;; 'total'=0.46GiB;;; [root@gs-cent8-23-82 greg]#
So please provide the output of the following (using sudo if required):Code: Select all
[root@gs-cent8-23-82 mysubdir]# mount -l ~ ~ ~ ~ ~ /dev/sdb on /greg/mysubdir type ext4 (rw,relatime)
Also send me a System Profile:Code: Select all
cat /etc/os-release uname -a mount -l cat /usr/local/nagiosxi/var/xiversion|grep full
Profile is attached and the output is down below (please note that this is Nagios VMware template server)
[root@fikc-nagxiprod01 ~]# cat /etc/os-release
NAME="CentOS Linux"
VERSION="7 (Core)"
ID="centos"
ID_LIKE="rhel fedora"
VERSION_ID="7"
PRETTY_NAME="CentOS Linux 7 (Core)"
ANSI_COLOR="0;31"
CPE_NAME="cpe:/o:centos:centos:7"
HOME_URL="https://www.centos.org/"
BUG_REPORT_URL="https://bugs.centos.org/"
CENTOS_MANTISBT_PROJECT="CentOS-7"
CENTOS_MANTISBT_PROJECT_VERSION="7"
REDHAT_SUPPORT_PRODUCT="centos"
REDHAT_SUPPORT_PRODUCT_VERSION="7"
[root@fikc-nagxiprod01 ~]# uname -a
Linux fikc-nagxiprod01 3.10.0-1160.36.2.el7.x86_64 #1 SMP Wed Jul 21 11:57:15 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
[root@fikc-nagxiprod01 ~]# mount -l
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
devtmpfs on /dev type devtmpfs (rw,nosuid,size=12245216k,nr_inodes=3061304,mode=755)
securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
tmpfs on /run type tmpfs (rw,nosuid,nodev,mode=755)
tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755)
cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,release_agent=/usr/lib/systemd/systemd-cgroups-agent,name=systemd)
pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
cgroup on /sys/fs/cgroup/hugetlb type cgroup (rw,nosuid,nodev,noexec,relatime,hugetlb)
cgroup on /sys/fs/cgroup/pids type cgroup (rw,nosuid,nodev,noexec,relatime,pids)
cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio)
cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer)
cgroup on /sys/fs/cgroup/perf_event type cgroup (rw,nosuid,nodev,noexec,relatime,perf_event)
cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices)
cgroup on /sys/fs/cgroup/net_cls,net_prio type cgroup (rw,nosuid,nodev,noexec,relatime,net_prio,net_cls)
cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset)
cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpuacct,cpu)
cgroup on /sys/fs/cgroup/memory type cgroup (rw,nosuid,nodev,noexec,relatime,memory)
configfs on /sys/kernel/config type configfs (rw,relatime)
/dev/mapper/centos-root on / type ext4 (rw,relatime,data=ordered)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=34,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=12714)
fusectl on /sys/fs/fuse/connections type fusectl (rw,relatime)
debugfs on /sys/kernel/debug type debugfs (rw,relatime)
hugetlbfs on /dev/hugepages type hugetlbfs (rw,relatime)
mqueue on /dev/mqueue type mqueue (rw,relatime)
/dev/sda1 on /boot type ext4 (rw,relatime,data=ordered)
sunrpc on /var/lib/nfs/rpc_pipefs type rpc_pipefs (rw,relatime)
tmpfs on /var/nagiosramdisk type tmpfs (rw,relatime,size=524288k)
fikc-isilon01.res.kcg.global:/ifs/data/fikc-nagxiprod01-backup on /mnt/nfs/backup type nfs (rw,relatime,vers=3,rsize=131072,wsize=524288,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,mountaddr=10.102.74.34,mountvers=3,mountport=300,mountproto=udp,local_lock=none,addr=10.102.74.34)
tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=2451384k,mode=700,uid=1000,gid=1000)
binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,relatime)
tmpfs on /run/user/0 type tmpfs (rw,nosuid,nodev,relatime,size=2451384k,mode=700)
[root@fikc-nagxiprod01 ~]# cat /usr/local/nagiosxi/var/xiversion|grep full
full=5.8.5
Thanks! I'll get this loaded after our afternoon staff meeting and will see if I get the same
results as you.
results as you.
gsmith wrote:Hi,
results as you.
Please update?
My apologies. I was out sick all last week and will work on this today.
Thank you.
Thank you.
Hi
When I look at your service definition for "resource - PROD /solr/suggestions volume used 90w / 95c" I see:
Please change it to:
$USER1$/check_ncpa.py -H $HOSTADDRESS$ $ARG1$
-t 'alfresco' -P 5693 -M 'disk/logical/|solr|suggestions/used_percent' -w 90 -c 95 -u G
-t 'alfresco' -P 5693 -M 'disk/logical/|solr|suggestions' -w 90 -c 95 -u G
This worked, thank you!gsmith wrote:Hi
$USER1$/check_ncpa.py -H $HOSTADDRESS$ $ARG1$ -t 'alfresco' -P 5693 -M 'disk/logical/|solr|suggestions/used_percent' -w 90 -c 95 -u G
Please change it to:Code: Select all
$USER1$/check_ncpa.py -H $HOSTADDRESS$ $ARG1$ -t 'alfresco' -P 5693 -M 'disk/logical/|solr|suggestions' -w 90 -c 95 -u G
- OK to close
