CPU Critical 100 alert sent as Warning?
MonitorGuy
Post by MonitorGuy »
Had a strange one this morning:
Using ncpa to monitor Windows servers
Check interval: 6 min
Retry interval: 1 min
Max retries: 4
cpu/percent -w '97' -c '100' -q 'aggregate=avg'
Alert notification:
Service: CPU Load \State: WARNING
Info: WARNING: Percent was 100.00 %
My guess? The monitor rechecked four times in four mins. so if the average calculated was less than "100" for the four checks (say 99.9%) the severity would be a Warning, not a Critical.
Unless someone else has a better explanation, I suggested changing the Critical threshold to 99%
check_ncpa.py, Version 1.2.4
Nagios XI 5.8.5
Thanks!
Craig
<<MonitorGuy>>
ssax
Dreams In Code
Re: CPU Critical 100 alert sent as Warning?
Post by ssax »
Correct, it's comparing with greater-than compared to greater-than-or-equal-to.
MonitorGuy
Thanks, will ask to change the Critical threshold at 99 instead of 100 to resolve.
Craig
<<MonitorGuy>>
ssax
Dreams In Code
Post by ssax »
Great, let us know when we're okay to lock this up and mark it as resolved.
MonitorGuy
I think we are good to go, Thanks!
<<MonitorGuy>>
ssax
Dreams In Code
Post by ssax »
If you want it to be greater-than-or-equal-to you could pass the thresholds like this:
cpu/percent -w '~:97' -c '~:100' -q 'aggregate=avg'
Taken from here:
https://nagios-plugins.org/doc/guidelin ... HOLDFORMAT
Locking the ticket and marking as resolved.
Thank you!
