check_ifoperstatus v2.3.3 (nagios-plugins 2.3.3)
Hi Team,
I am getting the below error for interface status monitor (attached the screenshot) for all interfaces on a device. Interface bandwidth data is available.
"check_ifoperstatus v2.3.3 (nagios-plugins 2.3.3)"
below is the error I am getting when I perform run check command for interface status monitor.
Also I have noticed the SNMP string (S9#!tM0n) which was configured is splitting into argument 1, 2 and 3 instead of showing in argument 1.
I have modified and placed in argument 1 but it shows another interface name which is not available in the device.
Can you please help in fixing the issue.
[nagios@spnidcnagiosxi ~]$ /usr/local/nagios/libexec/check_ifoperstatus -H 192.168.205.232 -C S9# -k tM0n 9
The nagios plugins come with ABSOLUTELY NO WARRANTY. You may redistribute
copies of the plugins under the terms of the GNU General Public License.
For more information about these matters, see the file named COPYING.
usage:
check_ifoperstatus -k <IF_KEY> -H <HOSTNAME> [-C <community>]
Copyright (C) 2000 Christoph Kron
check_ifoperstatus.pl comes with ABSOLUTELY NO WARRANTY
This program is licensed under the terms of the GNU General Public License
(check source code for details)
check_ifoperstatus plugin for Nagios monitors operational
status of a particular network interface on the target host
Usage:
-H (--hostname) Hostname to query - (required)
-C (--community) SNMP read community (defaults to public,
used with SNMP v1 and v2c
-v (--snmp_version) 1 for SNMP v1 (default)
2 for SNMP v2c
SNMP v2c will use get_bulk for less overhead
if monitoring with -d
-L (--seclevel) choice of "noAuthNoPriv", "authNoPriv", or "authPriv"
-U (--secname) username for SNMPv3 context
-c (--context) SNMPv3 context name (default is empty string)
-A (--authpass) authentication password (cleartext ascii or localized key
in hex with 0x prefix generated by using "snmpkey" utility
auth password and authEngineID
-a (--authproto) Authentication protocol (MD5 or SHA1)
-X (--privpass) privacy password (cleartext ascii or localized key
privacy password and authEngineID
-P (--privproto) privacy protocol (DES or AES; default: DES)
-k (--key) SNMP IfIndex value
-d (--descr) SNMP ifDescr value
-T (--type) SNMP ifType integer value (see http://www.iana.org/assignments/ianaiftype-mib)
-p (--port) SNMP port (default 161)
-I (--ifmib) Agent supports IFMIB ifXTable. Do not use if
you don't know what this is.
-n (--name) the value should match the returned ifName
(Implies the use of -I)
-w (--warn =i|w|c) ignore|warn|crit if the interface is dormant (default critical)
-D (--admin-down =i|w|c) same for administratively down interfaces (default warning)
-M (--maxmsgsize) Max message size - useful only for v1 or v2c
-t (--timeout) seconds before the plugin times out (default=15)
-V (--version) Plugin version
-h (--help) usage help
-k or -d or -T must be specified
Note: either -k or -d or -T must be specified and -d and -T are much more network
intensive. Use it sparingly or not at all. -n is used to match against
a much more descriptive ifName value in the IfXTable to verify that the
snmpkey has not changed to some other network interface after a reboot.
usage:
Usage:
2 for SNMP v2c
Re: check_ifoperstatus v2.3.3 (nagios-plugins 2.3.3)
Make sure that you surround the community with single-quotes.
Does this work from the CLI showing the proper port?
Edit the service and set $ARG1$ to 'S9#!tM0n' (with the single-quotes) OR add your SNMP community as a User Macro to $ARG1$:
https://assets.nagios.com/downloads/nag ... ponent.pdf
Then change $ARG2$ to 9.
Then change $ARG3$ to:
Save, Apply Configuration, and force a check.
/usr/local/nagios/libexec/check_ifoperstatus -H 192.168.205.232 -C 'S9#!tM0n' -k 9 -v 2 -p 161
-v 2 -p 161
I have added SNMP string in single quote but it gives the below error when I perform run check command.
[nagios@nagiosxi ~]$ /usr/local/nagios/libexec/check_ifoperstatus -H 192.168.205.232 -C 'S9#!tM0n' -k -v 2 -p 161
usage:
Usage:
2 for SNMP v2c
usage:
Usage:
2 for SNMP v2c
attached the screenshot.
Regards,
Preethu
Regards,
Preethu
You need to do this:
-v 2 -p 161
Thanks for the update.
I added ARG 2 & ARG 3 and I am able to see the node status as UP when I perform run check command.
But once I make the changes a "\" is coming automatically in string in ARG 1 (attached the screenshot) and if I do run check command again it display SNMP not responding.
I tried to removed "\" from SNMP string, but when I save the changes it is reappearing.
Reagrds,
Preethu
Reagrds,
Preethu
Also I have done the same changes for other interfaces but in status, it displays same interface name
Regards,
Preethu
Regards,
Preethu
SSAX is out for the next week. I am able to duplicate your issue:
Could you please run the following commands and provide me with the outout:
/usr/local/nagios/libexec/check_ifoperstatus -H 192.168.205.232 -C 'S9#!tM0n' -k 1 -v 2 -p 161
/usr/local/nagios/libexec/check_ifoperstatus -H 192.168.205.232 -C 'S9#!tM0n' -k 2 -v 2 -p 161
/usr/local/nagios/libexec/check_ifoperstatus -H 192.168.205.232 -C 'S9#!tM0n' -k 3 -v 2 -p 161
/usr/local/nagios/libexec/check_ifoperstatus -H 192.168.205.232 -C 'S9#!tM0n' -k 5 -v 2 -p 161
Below is the output. I ca see the status of interfaces, I need to monitor only specific interfaces, how do we know which value to keep for each interface. Also how we can eliminate extra "\" appearing in snmp string.
OK: Interface GigabitEthernet1/0/1 (index 9) is up.
WARNING: Interface GigabitEthernet0/0 (index 1) is administratively down.
WARNING: Interface Bluetooth0/4 (index 2) is administratively down.
OK: Interface Null0 (index 3) is up.
OK: Interface unrouted VLAN 1002 (index 5) is up.
Reagrds,
Preethu
Reagrds,
Preethu
Hi Preethu,
It is looking like the the \ is being added to escape the ! by the gui, but it shouldn't be doing that. I am
opening a bug report with the Dev team.
As an alternative you can try the /usr/local/nagios/libexec/check_ifoperstatusnag plugin that Nagios provides.
Another plugin you can try is at
https://labs.consol.de/nagios/check_nwc ... ndex.html
This plugin requires a different setup:
wget https://labs.consol.de/assets/downloads ... 3.1.tar.gz
tar zxf check_nwc_health-8.3.1.tar.gz
cd check_nwc_health-8.3.1
./configure
make all
make install
Then test it out against the device you want to monitor:
You can see the plugin help for other options:
You would need to reach out to the vendor of the device you want to monitor in order to determine what OIDs
you need to monitor as they will know the proper ones that meet your needs. We don't know this information.
Their support people or their website should have a list of MIB files you need for their device. You can look at the files,
or load them into a MIBbrowser to see what each OID represents.
Please let me know if you need assistance setting up one of these alternative plugins.
./configure
make all
make install
/usr/local/nagios/libexec/check_nwc_health --hostname X.X.X.X -t 60 --community 'yourcommunity' --mode cpu-load
/usr/local/nagios/libexec/check_nwc_health --hostname X.X.X.X -t 60 --community 'yourcommunity' --mode hardware-health
/usr/local/nagios/libexec/check_nwc_health --hostname X.X.X.X -t 60 --community 'yourcommunity' --mode memory-usage
/usr/local/nagios/libexec/check_nwc_health --hostname X.X.X.X -t 60 --community 'yourcommunity' --mode disk-usage
/usr/local/nagios/libexec/check_nwc_health --hostname X.X.X.X -t 60 --community 'yourcommunity' --mode interface-usage
/usr/local/nagios/libexec/check_nwc_health --hostname X.X.X.X -t 60 --community 'yourcommunity' --mode interface-errors
/usr/local/nagios/libexec/check_nwc_health -h
