This support forum board is for support questions relating to
Nagios XI , our flagship commercial network monitoring solution.
Amit_Alone
Posts: 89 Joined: Fri May 08, 2020 11:47 am
Post
by Amit_Alone » Tue Nov 02, 2021 2:57 am
Hi Team,
We have Nagios cloud i.e., 5.8.6v installed on Azure cloud. We had successfully enabled the baseline monitoring for cloud servers and it's working as expected.
However, when we are tried to enable the URL monitoring it's giving SSL connection error. We have tested the URL on the same browser on which Nagios GUI is accessible and it's working as expected. But after configuring it's showing below error.
[root@vlmazprdeu2nag2 ~]# /usr/local/nagios/libexec/check_http -H $$HOSTNAME$$.prod.cloud -f follow -I XX.XX.XX.162 -u "/quantum" -S -p 443
CRITICAL - Cannot make SSL connection.
139974179497904:error:14077438:SSL routines:SSL23_GET_SERVER_HELLO:tlsv1 alert internal error:s23_clnt.c:769:
[root@vlmazprdeu2nag2 ~]# /usr/local/nagios/libexec/check_http -H $$HOSTNAME$$.prod.cloud -f follow -I XX.XX.XX.162 -u "/quantum" -S --sni -p 443
139680030042032:error:14077438:SSL routines:SSL23_GET_SERVER_HELLO:tlsv1 alert internal error:s23_clnt.c:769:
Please assist me with the error
gsmith
Posts: 1253 Joined: Tue Mar 02, 2021 11:15 am
Post
by gsmith » Tue Nov 02, 2021 2:06 pm
Hi
Please try this:
/usr/local/nagios/libexec/check_http -H $$HOSTNAME$$.prod.cloud -sni -f ok -I XX.XX.XX.162 -u "/quantum" -S 1 -p 443
If that doesn't work please provide the output from it, as well as the output of this command that you
need to enter on the command line of the Nagios server:
curl -v -L https://HOSTNAME.prod.cloud/quantum
Amit_Alone
Post
by Amit_Alone » Wed Nov 03, 2021 1:17 am
I have executed the shared command and it didn't work.
[root@vlmazprdeu2nag2 ~]# /usr/local/nagios/libexec/check_http -H $$HOSTNAME$$.prod.cloud -sni -f ok -I XX.XX.XX.162 -u "/quantum" -S 1 -p 443
139667669346224:error:14077438:SSL routines:SSL23_GET_SERVER_HELLO:tlsv1 alert internal error:s23_clnt.c:769:
[root@vlmazprdeu2nag2 ~]# curl -v -L https://$$HOSTNAME$$.prod.cloud/quantum
* About to connect() to $$HOSTNAME$$.prod.cloud port 443 (#0)
* Trying 10.18.76.125...
* Connection timed out
* Failed connect to $$HOSTNAME$$.prod.cloud:443; Connection timed out
* Closing connection 0
curl: (7) Failed connect to $$HOSTNAME$$.prod.cloud:443; Connection timed out
gsmith
Post
by gsmith » Wed Nov 03, 2021 9:12 am
Hi
The curl command shows that the Nagios server can't connect to 10.18.76.125 on port 443.
From the Nagios server please try:
Amit_Alone
Post
by Amit_Alone » Wed Nov 03, 2021 10:44 am
Please find o/p of the requested command.
[root@vlmazprdeu2nag2 ~]# ping 10.18.76.125
PING 10.18.76.125 (10.18.76.125) 56(84) bytes of data.
64 bytes from 10.18.76.125: icmp_seq=1 ttl=124 time=331 ms
64 bytes from 10.18.76.125: icmp_seq=2 ttl=124 time=322 ms
64 bytes from 10.18.76.125: icmp_seq=3 ttl=124 time=323 ms
64 bytes from 10.18.76.125: icmp_seq=4 ttl=124 time=333 ms
64 bytes from 10.18.76.125: icmp_seq=5 ttl=124 time=323 ms
64 bytes from 10.18.76.125: icmp_seq=6 ttl=124 time=323 ms
64 bytes from 10.18.76.125: icmp_seq=7 ttl=124 time=322 ms
64 bytes from 10.18.76.125: icmp_seq=8 ttl=124 time=322 ms
^C
--- 10.18.76.125 ping statistics ---
8 packets transmitted, 8 received, 0% packet loss, time 7008ms
rtt min/avg/max/mdev = 322.074/325.206/333.616/4.357 ms
gsmith
Post
by gsmith » Wed Nov 03, 2021 4:00 pm
Hi
That looks good - thanks.
From a command line on the Nagios XI server please run:
/usr/local/nagios/libexec/check_http -H hostname.prod.cloud -S
note: the -S is an uppercase S
Amit_Alone
Post
by Amit_Alone » Wed Nov 03, 2021 10:12 pm
O/p of the requested command. I tried replacing hostname with IP still observing the same.
[root@vlmazprdeu2nag2 ~]# /usr/local/nagios/libexec/check_http -H $$HOSTNAME$$.prod.cloud -S
CRITICAL - Socket timeout
gsmith
Post
by gsmith » Thu Nov 04, 2021 9:55 am
Hi
From the Nagios server run:
If it doesn't say open then you need to check for a firewall on 10.18.76.125.
Do you have access to 10.18.76.125 ? If so run from the command line of 10.18.76.125:
If you don't have access to 10.18.76.125 talk to the administrator for
that machine and tell him you need access to port 443 from you Nagios server.
