How to upgrade nagiosxi command line
hdurans
Post by hdurans »
I have a question about to upgrade nagiosxi this is the actual version: 5.8.3 and I need to upgrade to 5.8.7 and the nagios have the database offsite,
which is the best form to upgrade the nagiosxi to version 5.8.7?
benjaminsmith
Re: How to upgrade nagiosxi command line
Post by benjaminsmith »
The upgrade script will use the offloaded credentials for the database, so the process is the same. Take a full backup or VM snapshot, log into the system as root, and run the following commands to upgrade.
cd /tmp
rm -rf nagiosxi xi*.tar.gz
wget http://assets.nagios.com/downloads/nagiosxi/xi-latest.tar.gz
tar xzf xi-latest.tar.gz
cd nagiosxi
./upgrade
Let us know if you have other questions.
Regards, Benjamin
References:
Nagios XI Upgrade Instructions
Backing Up And Restoring Your Nagios XI System
hdurans
Post by hdurans »
Thank you, for your help.
I do your recommendations and works fine.
Total Warnings: 0
Total Errors: 0
> Return Code: 0
Nagios XI Upgrade Complete!
You can access the Nagios XI web interface by visiting:
http://XXX.XXX.XXX.XXX/nagiosxi/
ssax
Dreams In Code
Post by ssax »
That's great to hear! Let us know when we're okay to lock this up and mark it as resolved.
