Logging user authentication
lmilkovic
Post by lmilkovic »
I have a question about logging standard user form-based authentication on the Nagios XI web interface.
As far as I know, details about user login are not stored anywhere - I tried to find them in Apache logs, Nagios logs, Nagios XI logs, NDO database and Nagios XI database, but I didn't find any data that indicates successful/failed user login.
I tried to correlate some data in the database with Apache logs, but without success.
Since Nagios XI login.php script is obfuscated with SourceGuardian, I cannot easily add logging code:(
Can anyone suggest a mechanism that could be used for logging user access (login) to Nagios XI web interface?
Thank you in advance!
Luka
Re: Logging user authentication
Luka,
Audit logging is slated to be added in the 2012 release coming in the next couple months.
lmilkovic
Post by lmilkovic »
Thanks Scott, that's great to hear!
Anyway, I hacked a quick solution that logs to AUTHPRIV log (/var/log/secure probably) when index.php is requested for the first time. There are some issues with this solution, but since I cannot edit login.php, I think it's a good workaround:)
Since I also had to track session duration, I added additional logging to deinit_session() in utils.inc.php. This part is working surpisingly well:)
Thanks for the feedback!
