Nagios XI report on Recent added Hosts
We are looking for a report to have recently added/removed hosts from Nagios XI in the past 'N' days. i looked up on reports and i dont find anything on that. Please help me in a way to generate a report.
benjaminsmith
Re: Nagios XI report on Recent added Hosts
Hi ITOMB_IMT,
In the web interface, go to Admin > System Information > Audit Log, and then choose Core Config Manager for the source. You should see a list of changes to the configuration such as when objects were added or removed.
Let us know if that helps.
--Benjamin
--Benjamin
This is good to view, but am looking for a report with just number on how many servers added and it to scheduled, so management can have overview on adding and decommissioning. IS there a way?
benjaminsmith
The best option would be to click the Download button in the upper right and download the info as a CSV file and import it into a spreadsheet for analysis.
Hope that helps and let us know if you have any questions.
--Benjamin
--Benjamin
we are looking for an automated report that sends that our organization email address. If the report doesn't work, is there a way i can query MySQL database and collect the required information for hosts added in last 30 days? if so what database i need to query? if possible can you post the query too.
benjaminsmith
It's stored in the nagiosxi database in the xi_auditlog table. Here's the table structure to assist with the required SQL query. A simple command to pull everything:
You could pipe this to grep and reduce this down to the desired output or modify the SQL syntax.
Regards,
Benjamin
echo "select * from xi_auditlog;" | mysql -u root -pnagiosxi nagiosxi
Regards,
Benjamin
Thanks for the information. I tried to query the database you provided, but it has provided me information from "2021-07-14 10:56:01" but nothing from before. from which database can i find the whole information on total servers added till date?
Hi
The age of entries kept for the audit log are set via Admin, Performance, Databases, NDO Database, Max Log Entries Age.
The default for this is 90 days, I am guessing yours is set for 180 days, so this is the limitation you are running into.
The functionality/data you are looking for does not exist. You would need to come up with a "home-grown" solution
to track the addition/deletion of hosts by date.
I have one more question. How can i am trying to a customize report showing all the details displayed in Host Status Summary. May i know ho can i get the numbers displayed for my report, by querying database? Which database i have to query for required output.
Thanks again.
Thanks again.
While this isn't querying the database, you might get the information you need from the API.
Take a look at Help, then pick "Objects Reference" on the left-hand menu under "API Docs",
and pick "GET objects/host" from the right-hand side. Please let me know what you think, and if I can close this thread.
Thank you!
Thank you!
