Thanks for following up, were you able to find the path location on the 'elasticsearch' service executable? I notice that on my test VM it is located in and can start with:
/etc/init.d/elasticsearch start
Circling back we see that you have a running java process with elasticsearch parms:
The java process listed is running elasticsearch with parms, so we should see that elasticsearch is serving requests (using curl on Linux). To verify:ps -aux | grep -Ei 'java'
nagios 16768 0.3 52.3 16131124 12843288 ? SLl Nov09 37:12 /bin/java -Xms11973m -Xmx11973m -Djava.awt.headless=true -XX:+UseParNewGC -XX:+UseConcMarkSweepGC -XX:CMSInitiatingOccupancyFraction=75 -XX:+UseCMSInitiatingOccupancyOnly -XX:+HeapDumpOnOutOfMemoryError -XX:+DisableExplicitGC -Dfile.encoding=UTF-8 -Des.cluster.name=c0d6d20a-0a3c-4d14-9cda-1f2f4fcb6b55 -Des.node.name=bec4d3fc-0bab-49f5-88cf-fb1094c85cfd -Des.discovery.zen.ping.unicast.hosts=localhost -Des.path.repo=/ -Delasticsearch -Des.pidfile=/var/run/elasticsearch/elasticsearch.pid -Des.path.home=/usr/local/nagioslogserver/elasticsearch -cp :/usr/local/nagioslogserver/elasticsearch/lib/elasticsearch-1.7.6.jar:/usr/local/nagioslogserver/elasticsearch/lib/*:/usr/local/nagioslogserver/elasticsearch/lib/sigar/* -Des.default.path.home=/usr/local/nagioslogserver/elasticsearch -Des.default.path.logs=/var/log/elasticsearch -Des.default.path.data=/usr/local/nagioslogserver/elasticsearch/data -Des.default.path.work=/usr/local/nagioslogserver/tmp/elasticsearch -Des.default.path.conf=/usr/local/nagioslogserver/elasticsearch/config org.elasticsearch.bootstrap.Elasticsearch
curl -XGET http://localhost:9200/_status?pretty
curl -XGET 'localhost:9200/_cluster/health?pretty'
Perry
