I'm doing the commands now and grabbing the files from the server and bringing them to my Windows machine and will send you a private message with the files.
FYI, the first command produced the following result:
[root@NagiosLogServer scripts]# tar -czvf /tmp/logs.tar.gz /usr/local/nagioslogserver/var/auditlog.log /var/log/httpd/ /var/log/apache2/
tar: Removing leading `/' from member names
/var/log/httpd/
/var/log/httpd/access_log-20211024
/var/log/httpd/error_log-20211128
/var/log/httpd/error_log-20211205
/var/log/httpd/access_log-20211209
/var/log/httpd/access_log-20211212
/var/log/httpd/error_log-20211212
/var/log/httpd/access_log-20211220
/var/log/httpd/error_log-20211220
tar: /var/log/apache2: Cannot stat: No such file or directory
tar: Exiting with failure status due to previous errors
