Nagios11 -Tomcat monitoring issue
ManishRezo1
Post by ManishRezo1 »
(No output on stdout) stderr: /bin/sh: 1: Syntax error: Unterminated quoted string
while monitoring tomcat 8 with nagios xi this is the error message .Any solution for this .......
kfanselow
Re: Nagios11 -Tomcat monitoring issue
Post by kfanselow »
Hi Manish,
Could you provide some more information on the problem ? Is this a new configuration or was it working previously ? What specifically were you doing and/or where did the error occur ?
The error message being returned is "Unterminated quoted string"
Thanks and Best Regards,
Keith
ManishRezo1
that was a file error . I was trying it ,without tomcat plugin .
New error I am Facing while connecting tomcat 9 with nagios 11 is .....
(No output on stdout) stderr: execvp(JAVA_ABS_PATH, ...) failed. errno is 2: No such file or directory
kfanselow
Post by kfanselow »
Hi Manish,
Are you setting up the check using the Apache Tomcat configuration wizard (Config {top} -> Configuration Wizard -> search for tomcat) ?
Keith
ManishRezo1
Yes i was doing the same .
But the problem was in java export path
By doing this ---
export JAVA_ABS_PATH=/usr/bin/java
source .profile
I t solved my problem
Thanks for the reply
ssax
Dreams In Code
Post by ssax »
That's great to hear! Let us know when we're okay to lock this up and mark it as resolved.
Thank you!
