How do I run check_winservice from nagios? I have successfully run it from target windows server but trying to invoke it with either command not found or nagios help prompt.
check_winservice
Re: check_winservice
Since it looks like you're using nsclient you'd want to add a command to nsclient.ini under scripts something like the following:
check_winservice = scripts\\check_winservice.exe $ARGS$
Then create a service in Nagios to run the command with the desired arguments on the Windows host.
That said, nsclient has an internal check_service command that can be used to check Windows services.
