Default username and password for Nagios Web UI
sanket
Post by sanket »
I'm trying to get access to Nagios web UI. When I click on "Access Nagios UI" option, I'm redirected to UI that has option only to enter username and password. I tried nagiosadmin and couple of other password listed in the admin guide- welcome. I went through the video on accessing this portal, however, video shows different page that should have program url, email, etc, however, in my case, I only see an option to enter information on username and password.
Any help will be greatly appreciated.
Sanket
Re: Default username and password for Nagios Web UI
Try resetting the nagiosadmin password by running in terminal:
./reset_nagiosadmin_password.php --password=<newpassword>
where you substitute <newpassword> with your password, for example:
./reset_nagiosadmin_password.php --password=welcome
Then try to log in the web interface again.
Hope this works.
sanket
Post by sanket »
Thanks! I tried that and I was able to successfully reset the password. I got a message that password reset successful for nagiosadmin.
However, when I try to login to UI, it shows the same message that username/password invalid. I restarted the server but the same message :(
any help appreciated!
Sanket
Do you have javascript enabled in your browser?
sanket
Post by sanket »
Yes..Using IE and Java script is enabled.
Can you post a screenshot (full page)?
sanket
Post by sanket »
Attached.
Do you have any "special characters" in the password? Please, review our wiki post on the topic here.
sanket
Post by sanket »
No..its a simplest possible password "admin"
In the "Username" field, do you enter "nagiosadmin" (one word, all small letters)?
