I have a Nagios XI server (5.8.7) running on 64 bit RHEL 7.9 manual XI install. The system uses SSL over port 443. Nagios and Linux are fully updated.
It's a minor issue and something that started happening recently, but when I modify a service description in CCM, the name change is no longer reflected in XI. I've tried removing and re-adding the host in the CCM service item, but in XI, the service description retains the old unmodified name (in CCM the name is correct).
Any suggestions on next steps?
service description change in CCM does not update in XI
Re: service description change in CCM does not update in XI
Hello @smapple
Thanks for reaching out.
Let's go ahead and reindex the Core Configuration Manager (CCM) configs by:
Perry
rm -rf /usr/local/nagios/etc/import/*
/usr/local/nagiosxi/scripts/reconfigure_nagios.sh
/usr/local/nagios/bin/nagios -vvv /usr/local/nagios/etc/nagios.cfg
Issue persists, please PM your system profile for us to review updates.
To send us your system profile.- Login to the Nagios XI GUI using a web browser.
- Click the "Admin" > "System Profile" Menu
- Click the "Download Profile" button
- Save the profile.zip file and send as Private Message
Perry
