Can't locate DBD/Oracle.pm in @INC
nagmites
Post by nagmites »
Hi there!
We have the oracle client version 11.2, Nagios XI 5.8.7, and installed the DBD module through CPAN and when using the check_xi_oraclequery command, it gives the error Can't locate DBD/Oracle.pm in @INC.
Some help?
Regards
pbroste
Re: Can't locate DBD/Oracle.pm in @INC
Post by pbroste »
Hello @nagmites
Found this here, please let us know if this helps:
scottwilkerson wrote:The document I am going to send is for Nagios XI, but page 6 outlines your scenario and how to remedy it
Perry
nagmites
Post by nagmites »
Hi there!
Fixed the error, I was importing wrongly LD_LIBRARY_PATH.
Now, work perfectly
Thank you for your help.
Best regards
pbroste
Post by pbroste »
Excellent find, @nagmites I will go ahead and lock this up.
Perry
