Setup Yum alerts with NCPA agent
gdolidze
Post by gdolidze »
We setup NCPA agents on our new redhat/centos 7 machines.
We used to use nrpe for alerts and now we switched to NCPA
How do we setup the new agent to alert us for yum updates.
pbroste
Re: Setup Yum alerts with NCPA agent
Post by pbroste »
Hello @gdolidze,
Thanks for reaching out, want to suggest checking out the plugins found in the Nagios Exchange.
To find more checks using NCPA, the easiest way is to access to Web GUI for NCPA and use the API.
https://www.nagios.org/ncpa/getting-sta ... ng-the-gui
Here is the help documentation, which has a lot of information on NCPA itself.
https://www.nagios.org/ncpa/help.php
Using Nagios plugins with NCPA is the best way to get the checks you want. Here's an example
/usr/local/nagios/libexec/check_ncpa.py -H 192.168.x.x -t '<your token>' -M 'plugins/check_yum/<the_switches_here>'
Let us know how this goes!
Perry
