Nagios XI 2011R2.4
Is it possible to have Nagios notify one group or contact when a service reports a "Warning" level and another group or cantact when the same service reaches a "Critical" level?
Thank You.
Nagios Alerting
Re: Nagios Alerting
Yes.
You would use the Service Escalations for this
Configure -> CCM -> Alerting -> Service Escalation
You can set 2 different escalations for the same service setting the "Escalation options" to the appropriate one of each
