Retrieve current username from a quick action
WillemDH
Post by WillemDH »
We have a need to create a quick action, which is able to know the Nagios XI username of the logged in Nagios XI user who clicked the quick action. I could not find any reference to such a macro in for example https://assets.nagios.com/downloads/nag ... ios-XI.pdf
Is this already possible and if so, what macro or variable can we use to get the current username and use it in the script that's being called from the quick action?
Best regards,
Willem
Nagios XI 5.8.1
https://outsideit.net
gsmith
Re: Retrieve current username from a quick action
Post by gsmith »
Hi
Please create a ticket in our new Support system:
We're moving to a new support system!
The Nagios Answer Hub is a place where you can get help with technical questions from our experts. There, you can quickly open tickets and join discussion boards.
Request Nagios Answer Hub access here: https://info.nagios.com/answer-hub-access-new-users
After completing the access form, you will be given access to a portal where new tickets can be created. We will keep the old customer forum sections and ticket system available for current cases to be resolved.
Thanks!
