check_Http issue
vivek
check_Http issue
Post by vivek »
The problem is that, I've been trying to run the command "check_http -I $HOSTADDRESS$ -H vhost.host.net --ssl -u/url --post='login=username&password=password' on a Sharepoint 2010 site and I get the error "Could not establish SSL connection.
And when I tried "$USER1$/check_http -H $HOSTADDRESS$ -S -a username:password" , the error comes as HTTP WARNING: HTTP/1.1 401 Unauthorized Command returned exit status 1
Both the commands work with an other Sharepoint host but does not work on many other Sharepoint hosts.
Please help me
ecarrasq
Re: check_Http issue
Post by ecarrasq »
Try:
http://exchange.nagios.org/directory/Pl ... pl/details
check_sharepoint.pl
Works with both integrated NTML and forms based authentication.
