I've installed nagios 5 times now, to make sure I'm not doing anything wrong. And when I go to load the webpage at the end, I get a red X with "Unable to get process status" under the Nagios Core logo.
Does anyone know what this could be caused by? I followed all instructions per nagios installation guidelines.
DisastoArea
Re: Unable to get process status
I had the same problem.
This information helped me.
https://github.com/NagiosEnterprises/na ... issues/861
/usr/local/nagios/etc/nagios.cfg
set --> from check_for_updates=0
DisastoArea
Solution:
Set:
check_for_updates=0
Solution:
Set:
check_for_updates=0
