I'm getting a (No output returned from plugin) from a host and cannot understand why:
Service on monitor server:
# Check Clamd availability
hostgroup_name clamd-servers
service_description ClamAV Daemon
check_command check_nrpe!check_clamd
notification_interval 0 ; set > 0 if you want to be renotified
Hosts on monitor:
# Clamd Servers
define hostgroup {
alias ClamAV servers
members fsmvps
nrpe_local.fcfg on host fsmvps
command[check_clamd]=/usr/lib/nagios/plugins/check_clamd -H /var/run/clamav/clamd.ctl
Running the command /usr/lib/nagios/plugins/check_clamd -H /var/run/clamav/clamd.ctl on the host will produce the following output as clam is up and running:
CLAMD OK - 0.000 second response time on socket /var/run/clamav/clamd.ctl [PONG]|time=0.000219s;;;0.000000;10.000000
Clueless at the moment as to why no output is echatspin echatrandom returned as I'm a beginner on Nagios.
Setup Nagios check_clamd
TuqueroIMK852
Last edited by TuqueroIMK852 on Mon Nov 28, 2022 11:51 pm, edited 1 time in total.
Re: Setup Nagios check_clamd
Are you testing as the nagios user?
