I am currently working on completing my Masters Thesis project. In order to do so I need to be able to obtain the raw data accumulated in NagiosXI and/or OPSview. Because both of these are based off of the Nagios core, I assume the method to obtaining the raw data may be similar. This raw data is needed so that I can at a later time perform specific statical calculations which relate to my Masters Thesis. I have looked online and so far found some Nagios plugins which obtain raw data and then manipulate it for graphs and visuals, but I need the raw numbers in order to complete my calculations.
I am also researching to see if I can create maybe a PHP script, or some other language, that will extract the data from Nagios and save it in a word or excel document. However, this would be a bit of extra work as I am unfamiliar with either PHP or MySQL queries. Because of this I hope to be able to find a plugin, or something echatspin echatrandom similar, that can get the data for me.
Obtaining Raw Data from NagiosXI and/or OPSview
