NCPA - '[Errno 104] Connection reset by peer'
Re: NCPA - '[Errno 104] Connection reset by peer'
The token field is empty. That's the field ncpa uses for authentication. Can I give you some good advice? You'd be doing yourself a huge favor if you dig into the documentation on their website. For just about anything you need to do, there's plenty of info.
Did adding the token resolve your issue?
i never use the token field, leave it empty.
I can try to add.
Firewall is already disabled
I can try to add.
Same meesage with token.
Hi, I have the same issue,
[XXX@XXXX ~]$ /usr/local/nagios/libexec/check_ncpa.py -H **** -t ***** -M disk -l
UNKNOWN: An error occurred connecting to API. (Connection error: '[Errno 104] Connection reset by peer')
with nmap the port is open
PORT STATE SERVICE
5693/tcp open rbsystem
$ curl -v https://****:5693
* Rebuilt URL to: https://****:5693/
* Trying ****...
* TCP_NODELAY set
* Connected to ****(****) port 5693 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* successfully set certificate verify locations:
* CAfile: /etc/pki/tls/certs/ca-bundle.crt
CApath: none
* TLSv1.3 (OUT), TLS handshake, Client hello (1):
* OpenSSL SSL_connect: SSL_ERROR_SYSCALL in connection to ****:5693
* Closing connection 0
curl: (35) OpenSSL SSL_connect: SSL_ERROR_SYSCALL in connection to ****:5693
you have any solution?
PORT STATE SERVICE
* Trying ****...
* TCP_NODELAY set
* ALPN, offering h2
CApath: none
- jmichaelson
Are you able to connect to the NCPA client with a browser? i.e., go to https://ip address:5693/?
Ignore the ssl warning that will appear, and use your token to log in.
-Jason
-Jason
Yes, I try to other server and url respond and I log in sussessfullyjmichaelson wrote: ↑Thu Feb 15, 2024 5:20 pm Are you able to connect to the NCPA client with a browser? i.e., go to https://ip address:5693/?
on my side, it was a firewall dropping the flow, even if i catched it using telnet.
