Run a local shell script by using NCPA
Post Reply
titien104
Post by titien104 »
Hi Team,
I have a shell script as below:
/opt/TEST_CDC/cdc-processor-audit/bin/audit-processor.sh 0 2500
This script will start up this JVM:
/opt/java/java8/latest/bin/java -Duser.timezone=Pacific/Honolulu -Xms256m -Xmx512m -cp config:./lib/* -Dlog4j.configuration=file:config/log4j.xml -Dcom.med.common.globals=config/audit-processor-globals.xml -DspringConfig=springConfig/processorContext.xml -Dcom.med.rpt.eventprocessor.commons.GenericSpringInvoker.bean=pipelinedEventCopier com.med.rpt.eventprocessor.commons.GenericSpringInvoker copy 0 2500
How do I use NCPA agent to monitor and start up the script if the jvm is stopped any any reason?
kg2857
Re: Run a local shell script by using NCPA
Post by kg2857 »
You might want to look into running plugins via ncpa.
titien104
Post by titien104 »
Thanks kg2857,
I am not an expert with NagiosXI. Can you or someone provide more detail instruction? Thanks
deby23456
Post by deby23456 »
Here is some information describing plugins.
https://answerhub.nagios.com/support/s/ ... s-f9e78907
If you want to test it out and get some deeper knowledge about the use of it. I'd start with this KB below.
https://answerhub.nagios.com/support/s/ ... s-7fb3d9a8
If you want to reboot a service if it goes down though. That may need an "event_handler." Check out this article as well.
https://answerhub.nagios.com/support/s/ ... s-dd07d938
maxvilliams
Post by maxvilliams »
Make sure NCPA is installed and configured on your system. NCPA is a monitoring agent that allows you to execute commands remotely, including running shell scripts. Locate the "Plugins" section in the NCPA interface. This is where you can execute various commands and scripts. In the NCPA interface, navigate to the "Plugins" section and find the option to execute a command or script.
This website https://casinowis.com/free-slots-no-deposit provides an exciting and risk-free way to enjoy your favorite slot games without having to spend any money upfront.
Post Reply
