email issue: Unable to bind parameters & Statement not prepared
JohnFLi
Post by JohnFLi »
Our Nagios version: 5.10.0
our nagios xi is set to use 'send mail'
in trying to find out why some (only some) messages are not being sent out for alerting.
I look in /usr/local/nagios/var/nagios.log file and i see:
[1687186711] NDO-3: ndo_return = 1 (Statement not prepared)
[1687186711] NDO-3: ndo_handle_system_command(ndo-handlers.c:334): Unable to bind parameters
any thoughts?
Everybody is somebody else’s weirdo
kg2857
Re: email issue: Unable to bind parameters & Statement not prepared
Post by kg2857 »
I'd guess the DB needs a repair.
Marilian
Post by Marilian »
All data that is not specific to the hosts is placed into one or more templates that I design. Then, have a script generate the template, hostname, and address into separate host.
amanda the adventurer
Lillian
Post by Lillian »
It typically encountered in database operations, specifically when using prepared statements.
jsimon
Post by jsimon »
Hi @JohnFli,
We have a guide for enabling phpmailer debugging here.
Following these steps and enabling debugging during a period you would expect alerts to go out should provide more insight into the issue. Please let us know if you run into any trouble with these steps. Otherwise, let us know what errors you're finding for additional steps.
jmichaelson
Post by jmichaelson »
My question, since this is a year old thread, is whether this happens on Nagios XI 2024R1.1.x? I'd recommend updating to a newer version of XI as soon as reasonably possible.
-Jason
